mkblade
| posted on 29/4/08 at 10:48 PM |
02 machine gas analyser
as above im sure my 919 blade is running rich as its just fouled up another set of plugs
ive fitted the new dyno jet kit ,new k&n filter set the mixture screws 2.5 turns out
it hasnt had a good run in ages but it will soon
has any one used or know if the gases can be checked like when you have a mot ??
thanks
simon
Big Stu
| posted on 30/4/08 at 10:02 AM |
You can use a lamda sensor in the exhaust which you can either hook up to an air / fuel ratio meter (about £30) or just measure the voltage across the
signal wire to earth. Correct mixture should be about 0.5v.
adithorp
| posted on 30/4/08 at 12:04 PM |
The machine will give live reading at test but it'll depend how well you know the tester as to wether he'll let you fiddle while
he's testing.
adrian
