Detailed Gear And GearBox Description
Specifications:
a) Manual transmission with three - shafts
b) Separated structure is designed to reduce maintenance costs
and expand series products easily
c) Adopts aluminum - alloy case and cast iron intermediate plate for
a lightweight structure with big torque and low noise operation
d) All gears adopted optimum designed spindly teeth and precision
shot peen gear faces and roots to decrease noise of and
increase carrying capacity
e) Forward gear with synchronizer with unique structural design for
fifth and reverse gear which decreases synchronous moment of
inertia and shift force
f) Low reverse gear is designed to decrease lock rate and the
shifting gear lock is adopted to avoid reverse gear shifting in
error when shifting out of fifth gear
g) With a remote control and cable ideal for use on buses, pickups, MPVs,
SUVs and other light vehicles
h) Suitable for assorted engines or chassis
Technical parameters:
a) Max. input power: 102kW / 5,400rpm
b) Max. input torque: 200N. m /3,000rpm
c) Center distance: 72mm
d) Ratio: (1st, 3rd, 2nd, 4th, 5th, )
1) 3.70, 2.02, 1.37, 1.00, 0.80, 4.47
2) 3.93, 2.33, 1.45, 1.00, 0.85, 4.74
3) 4.45, 2.40, 1.41, 1.00, 0.80, 4.47
4) 4.45, 2.62, 1.52, 1.00, 0.85, 4.47
5) 5.01, 2.95, 1.71, 1.00, 0.9, 5.03
6) 3.99, 2.15, 1.33, 1.00, 0.85, 4.22
e) Ratio of speedometer: 17, 19, 18, 20, 21, 22 / 5, 6
f) Lubrication oil type: 75W / 90 (GL - d)
g) Oil capacity: 2.0L
h) Weight: 32kg
i) Applicable engine: 491 (Toyota: 3Y, ), 4G24
(Toyota: 2RZ, )
j) Applicable vehicle: coach bus, MPV (Toyota: )
