dunk
| posted on 3/5/08 at 12:19 AM |
Engine ideas
Hi i have been reading through the forum for a few weeks now and i thought it was about time i started posting. So here goes, i have a Suzuki
offroader and i have upgraded the engine to a 1.6 Vitata engine but the engines are not that strong and crack blocks for fun ( I am now on my 10th). I
need to find a cheap lightweight engine to replace it with when the one i have in goes pop. i was thinking along the lines of a 1,8 zetec lump with a
type 9 or mt75 box fitted to it but thats as far as i have got. Tbh i am not that hot on these engines with regards what will fit with what. I know
the zetec has no dizzy so i will need to find a way round that and deep water and mud don't go well with electrics. The other thing i have been
trying to find out is what single carb and manifold i can use on the zetec engine as i need to attach a snorkel to it. Here's a pics of my jeep.
Thanks in advance Duncan
dunk
| posted on 3/5/08 at 12:20 AM |
Another one
D Beddows
| posted on 3/5/08 at 01:20 AM |
What's the point of the Suzuki then? competition? fun? your day to day car with added weekend fun? I'm not being difficult but it's
an important factor you've not told us I'm also a bit intrigued by the need for a lightweight engine???
I used to build tuned land rover engines for a living and one of those would seem an ideal contender, actually not really much bigger or heavier than
a Zetec E to be honest - not quite so many horsepowers perhaps (not far off though if done properly) but quite a lot more torques....probably not the
locost option mind you
[Edited on 3/5/08 by D Beddows]
aerosam
| posted on 3/5/08 at 05:50 AM |
Not just my wife's Vit that happens to then? Rubbish car the vitara, will be replacing it soon.
big_wasa
| posted on 3/5/08 at 05:53 AM |
Single carb on the zetec would be the Dgav 32/36. Manifolds on ebay aimed at the banger racers.
Ignition taken from the ford fiesta, just two wires to run. 12v and earth. Very cheap. I dont know how it would work with the crank sensor submerged
in water though.
snapper
| posted on 3/5/08 at 07:16 AM |
All the electrics will need sealing but you know that anyway.
You could easily make the injector electrics and maff sensor electrics watertight and connect the air intake for the maff to your snorkle.
If you removed the injection system you would still need an ECU to drive the spark so make it easy and just instal the lot as Mr Ford intended, that
way if you blow another engine it will be a simple job to slot in another.
I eat to survive
I drink to forget
adithorp
| posted on 3/5/08 at 07:41 AM |
You'll have to find a way of stopping the spark plug gallery (best description I can think of) from filling with water. We've had several
come into work with horrendous missfires that turn out to be flooded between the cams where the plugs are...and thats on Focus' (should that be
Foci).
adrian
dunk
| posted on 3/5/08 at 07:49 AM |
Thanks for your replies.
D Beddows. Its a fun thing. I do intend to do a few trials in it at some point. The zuke is an offroader only as i have a welded rear diff. I will go
back on the road at some point as i have a spare diff. The Land Rover engine is a bit on the large size for the engine bay, i am looking for a small
cheap and easy to fing engine. Lightweight is the key to the suzukis success offroad. At just under 1200 kg it skips over stuff that Land Rovers just
get bogged down in. So i don't want to loose that advantage.
aerosam. Yes the engines are rubbish but i have to say they dont get an easy life in my Suzuki. The engine is given plenty of beans most of the
time.
big_wasa. If my memory servs me right that carb is the pinto carb? So what manifold is it a specially made one or from the Ford range. I like the
sound of just two wires and a crank sensor. That sounds like just the thing i was after. Any special type or year of fiesta ? I will have to try to
find a way of keeping the crank sensor clean.
Snapper. I would love to keep the injection but i think it may be to much stuff that is going to get wet. My Suzuki regulary goes over the dash with
water so the less electrics and more simple it is the better.
Had a thought last night. I wondered if i could fit an auto box to a zetec as auto offroad is awesome. Duncan
dunk
| posted on 3/5/08 at 07:53 AM |
Foci).
adrian
Yeah i had thought of that and the only things i could think of was using the offroaders friend silicone and if that dont do the trick then silicone
it up and use a compressor or an air horn to put positive pressure in there so the water stays out.
| posted on 3/5/08 at 08:01 AM |
You could look at a Kia Sportage engine, 2.0 16 valve Mazda derived , already 4wd Getrag gearbox. I bought one when my van went and it's a nice
motor.
[Edited on 3/5/08 by Peteff]
| posted on 3/5/08 at 09:34 AM |
Right then, here we go... how about a Corsa 1.5TD or Astra 1.7TDi??
Its a Isuzu engine, small and gives good torque and power, very easy to fiddle with the pump and get it flying.
zilspeed
| posted on 3/5/08 at 03:00 PM |
in water though.
Oohh, likey !
I know it's very low tech, but that manifold idea is V. Locost to me.
http://cgi.ebay.co.uk/mondeo-manifold-for-banger-raci
ng_W0QQitemZ190218442332QQcmdZViewItem
dunk
| posted on 3/5/08 at 03:06 PM |
Its a Isuzu engine, small and gives good torque and power, very easy to fiddle with the pump and get it flying. [/quote
Nice idea. Its been done may times before with a manta gearbox. There are a few things i dont like about fitting that engine. One is the weight as its
a heavy lump and the other is you have to go spring pearch over axle as the sump is to low and i dont like spoa zukes as they are to tippy and tend to
fall over alot.
big_wasa
| posted on 4/5/08 at 09:15 AM |
yep two wires to run and three plugs and a vacume pipe to conect to the engine.
Coil, crank position, water temp. and a vac connection for the advancing the ignition.
demo
NS Dev
| posted on 4/5/08 at 09:53 AM |
Hi, good to see something different on here!!
Personally, I would shun Ford stuff on this one and turn to vauxhall.
Go for a Vauxhall Carlton 2.0 ohc single cam engine and rwd gearbox.
The GM gearbox is nice and short and quite strong (the shift/lever assembly shortens very easily)
The engines are absolutely bulletproof, and you can just install it with the standard injection still attached, just piped up to the snorkel. So long
as you rubber bag the ecu it will be fine.
The crank sensor on these is inside the crankcase so no issues there.
They are 115hp as std, or you could just go for the carlton gearbox and bolt on the front wheel drive cavalier sri 8 valve engine which is 130hp as
std.
I sugegsted the carlton 115hp one as they are slightly torquier low down in the rev range and its less work to fit it.
This conversion has been done a few times to lada nivas so you may have seen it done before.
If you need any help I have fitted these engines to most things over the years, though not a suzuki jeep yet!!
NS Dev
| posted on 4/5/08 at 09:55 AM |
PS if you dont want to run the injection system, then a std cavalier inlet manifold and distributor will fit straight on from a 1.8 carbed cavalier.
stevebubs
| posted on 4/5/08 at 10:10 AM |
Foci).
adrian
try running one with a huge hole in your bonnet and the engine sticking out!!
dunk
| posted on 4/5/08 at 04:19 PM |
Big_wasa. Nice work on your engine, what fiesta do i need to get the bits off ?
NS Dev. The problem is the sump clearance with the vx engines i would have to go SPOA and i dont want to do that to my truck. A mate of mine had a 2.0
vx Carlton engine in his Sj and it used to rip the t-box out for fun.
I dont really need mega power the Vit engine i have at the moment is around 80bhp and thats enough.
Another question. Can i fit an auto box to a Zetec engine ?
Stevebubs. Nice idea but i dont think i can get it high enough. This is a pic of my mate and my Mrs from Wales last year when we found a hole. It was
still running for quite a while underwater but his snorkel had a leak and the engine filled with water. I towed him out, took the plugs out, turned it
over to get the water out then popped the plugs back in and tow started it. Its still running spot on now.
stevebubs
| posted on 4/5/08 at 05:49 PM |
My comment was more aimed at the "keeping the plug gallery dry" based on personal experience
dunk
| posted on 4/5/08 at 09:09 PM |
See what you mean Steve must be a bit of a pain. But seeing the engine through the bonnet is quite cool
NS Dev
| posted on 4/5/08 at 10:00 PM |
Hi Dunk, pardon my stupidity but whats "SPOA"??
take it on the power though, wasn't sure what the suzuki transfer box would take!
zilspeed
| posted on 5/5/08 at 03:17 PM |
Can I have a guess ?
Sump Pan Over Axle ?
Nah, can't be, surely...
dunk
| posted on 5/5/08 at 03:54 PM |
SPOA means spring perch over axle. So in standard set up the axles is no top of the leaf springs. When you do a spoa conversion the axle goes under
the leaf springs. So you gain about 6 inches of hight and have no sump clearance problems. But mine is axle set up as standard with 3 inch lifted
spings and 1 inch missing links with ruf springs (rears up front) so the axle is 1 1/2 inches further forward to help with sump, wheel clearance and
flex as the longer the spring the more it flexes.
stevebubs
| posted on 11/5/08 at 07:16 PM |
It certainly drew a lot a attention when parked up....
At Le Mans, people would wander past the other 7/8 kits I'd be parked up with and you could see them stop and do a double take at mine...
Got a bulge over it now, though!
stevebubs
| posted on 11/5/08 at 07:17 PM |
PS What about a 1.6 ford sigma ?
Smaller and lighter than the zetec...
