DorsetStrider
| posted on 5/5/08 at 06:34 PM |
Zetec Vs Ecotech
Hiya all.
As you know I've been planning my build around a zetec engine... however today I was semi offered a vectra with an ecotech engine.
I have to be honest I don't know a great deal about vauxhall engines... what are the pros and cons of the ecotech? Would it make a good donor
engine?
As always any help and advise is as always gratefully received.
Who the f**K tightened this up!
blakep82
| posted on 5/5/08 at 06:55 PM |
ecotec is pretty much the same block as the XE redtop, type 9 gearbox will fit, the bellhousing's the same pattern (only you will want a sierra
clutch from anything EXCEPT the 2.3l diesel) so fitting's not a problem.
power on the ecotec is down a bit from the XE (-20hp i think) but apparently, i'm told, thats down to the stock intake, and making the
'eco' in ecotec
as for zetec vs ecotec... i don't know
________________________
philw
| posted on 5/5/08 at 07:17 PM |
I run an Ecotec in my Stylus in standard trim they kick out 136bhp, they are not as strong as the XE due to vauxhall making it in just enough kind of
way, rods etc (if that makes sense) on the plus side you can use an Opel manta gearbox, flywheel and clutch and the manta flywheel only weighs
5kgs(which for an XE flywheel of that weight you will pay a lot) you can do the obvious ARP bolts etc, mine kicks out about 198bhp with TBs and some
head work and a set of cams and verniers,but i think thats about it power wise as the heads arn't known for big power having said all that i did
throw a rod last year on a trackday but i'm sure that was somthing i did whilst working on the engine the day before, prior to that i had done
about 1500 mile caining the arse off of it with no trouble, on the bright side Ecotecs are cheap and easily replaceable as for Zetec v Ecotec i would
go for a redtop/XE but thats my choice.
HTH
Phil
blakep82
| posted on 5/5/08 at 08:05 PM |
198? what exactly did you do? i'm having my ecotec rebuilt now to run in bike carbs. 200bhp would be nice, but i'm not really looking at
spending big money yet
Dusty
| posted on 6/5/08 at 12:14 AM |
........ as for Zetec v Ecotec i would go for a redtop/XE ........
I have to say in the Zetec v Ecotec I would go for Duratec personaly.
philw
| posted on 6/5/08 at 02:36 PM |
Yeah you are right, all alloy nice and light but still a touch expensive.
philw
| posted on 6/5/08 at 02:55 PM |
It was one of those rare Ebay bargains ( i mean pennies) nobody wanted it because it was an Ecotec, anyway advert was somthing like VX engine with
weber 45s lots of paperwork very fast blah blah, anyway i've gone to collect it and it has Weber Alpha gold TB kit (so i'm quids in
straight away) the head was worked by a company called auto craft not sure what they did but the exhaust ports are huge compared to a standard head (
i must have a look at the inlet side) it already had vernier gauges and a RR print out showing 185bhp, so all i have done is put a set of EC2001 cams
in which claim + 12-15bhp a manta flywheel which saves about 3-4kgs over a standard one and thats about it the only thing i could do with is a better
exhaust manifold, this is probably not much help, i will try and find the paper work and see if that gives anything away.
Phil
blakep82
| posted on 6/5/08 at 03:27 PM |
^ ah, no thats spot on for now! ok, so i can't afford weber TBs, but bike carbs, a bit of head work and vernier pulleys should hopefully give
some decent gains anywayi'd be happy with 160-170bhp to start.
but if you could find out what work was done to the head, that would be fantastic
