mr henderson
| posted on 7/5/08 at 08:42 PM |
Zetec with broken cam-belt, waste of time?
Is it even worth opening up, or should be be exchanged or replaced?
I know of a donor that I can get lots of good bits off, but don't know if it's worth messing with the engine at all
| posted on 7/5/08 at 08:44 PM |
1.8 or 2.0??
Mole
| posted on 7/5/08 at 08:55 PM |
They are that cheap it's hardly worth the effort.
Monkeybasher
| posted on 7/5/08 at 09:09 PM |
16 bent valves on a focus i did. Idler pulley broke up, slapped a new head on it. Its all good now.
Was a 2.0l paid about £170 for a head. I couldnt be arsed taking the engine out though, hence I just did the head
[Edited on 7/5/08 by Monkeybasher]
mr henderson
| posted on 8/5/08 at 06:48 AM |
It's a 1.8, but I see a consensus emerging here, and as a car in GWO can be got for £400 odd I'm inclined to agree.
Thanks for the input
| posted on 8/5/08 at 07:05 AM |
A lot less than £400 --- less than 200.
Although probably only between 6 and 10 valves will be bent but the chances are you will find valve guide damage.
mr henderson
| posted on 8/5/08 at 07:08 AM |
So to sum up, do you think the chances are good of an inexpensive repair?
Monkeybasher
| posted on 8/5/08 at 08:02 AM |
valves are quite cheap cant remember exactly
£4 for on type (inlet or exhaust)
£7 for the other
very rough prices
But say you bent 8 of the cheap ones its only £32 plus gaskets and time.
I personally would take the head off and have a look. see how many are bent. Wont take long.
or ditch it and get a 2.0l
