Author: Subject: Bellhousing
posted on 7/5/08 at 09:17 PM Reply With Quote
Bellhousing
Flogged to death this one but I've searched the archives and can't find what I'm looking for.
I have a Toyota W58 (Supra) gearbox I want to fit to the back of a Zetec engine. Popular swap down under but not used much over here....
The Toyota bell housing is about 5mm shallower than a type 9 bell housing. I was thinking about cutting the back off the Ford housing, welding a new plate on the back and making the Toyota 9 bolt pattern fit that.
Before I go down that route is there an easier combination? I don't want to buy anything from Oz or NZ as A) they expensive and B) not much for 4 the titchy 4 cylinder engines we use.
This is the box I'm sure you've all seen before. Good for 600bhp they reckon...... Rescued attachment XT BOX 2 small.JPG
Volvorsport
posted on 7/5/08 at 10:40 PM Reply With Quote
wont a cossie box fit ?
why does it need to hold 600 hp ?
www.dbsmotorsport.co.uk
getting dirty under a bus
posted on 7/5/08 at 11:17 PM Reply With Quote
I have to say that an MT75 or Type9 box would save you a world of pain, and the MT75 in particular is more than adequate for the kind of power you can reliably extract from a Zetec unless you are getting very serious with tuning it.
posted on 8/5/08 at 06:58 AM Reply With Quote
Well, its only as I have that box lying around and I want to push a zetec turbo through it....
May abandon the whole exercise and get a Rover turbo engine and Landrover box.. another can of worms!
I'm itching for the next PPC which is going to have an engine to box list in it
posted on 8/5/08 at 05:57 PM Reply With Quote
Adaptor plate? If you want a cast bell housing for a type 9 I have one I keep tripping up over but you would have to collect.
Volvorsport
posted on 8/5/08 at 06:43 PM Reply With Quote
mt75 is good to 375 hp apparently .
are you actually aiming higher than that ?
posted on 8/5/08 at 06:54 PM Reply With Quote
Zetec @ 375bhp = fragmentation grenade
