CraigJ
| posted on 10/5/08 at 05:06 PM |
Running a C20XE whats needed?
What is needed to run an XE from a calibra/astra gsi in a kitcar from the doner?
Is the 20XE on a distributer or coil packs cant remember?
Engine
engine loom
ecu
alternator
gearbox+driveshafts (engine will be mid-mounted)
inlet + exhaust manifold
Anything else?
MkIndy7
| posted on 10/5/08 at 05:21 PM |
THe XE's are both Dizzy and coil pack depending on their age.
There've got good fuel pumps as well.
Bigheppy
| posted on 10/5/08 at 05:36 PM |
Petrol
chrsgrain
| posted on 10/5/08 at 07:37 PM |
I ran the original induction / injection system to begin with, but it won't fit under most bonnets - if you do go that way you'll need a
'power cap' to take the place of the original airbox in order to squeeze it in.
Most people eventually go carbs and dizzy / megajolt, or throttle bodies, these are both much smaller and give more power....
Also - most people ditch the alternator for a denso one, for size issues...
Chris
[Edited on 10/5/08 by chrsgrain]
