Author: Subject: Knackered engine ?
clairetoo
posted on 10/5/08 at 06:35 PM Reply With Quote
Knackered engine ?
I had my engine running today , mainly to see how close the fueling was - I have a basic Co meter and a wideband sensor set-up .
The worrying thing is - the meter is showing 3.5% on the right hand bank , and 12.5% on the left
There is allso noticeable white smoke from the left hand exhaust which gets less as it warms up .
Any ideas ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
big_wasa
posted on 10/5/08 at 06:38 PM Reply With Quote
rings or valve stem seals.
Do a compression test
clairetoo
posted on 10/5/08 at 06:44 PM Reply With Quote
Oh fudge
Aint got a compression tester..........and dont fancy doing a rebuild on a quad cam V6
Anybody got a spare 2.5 ford probe V6 they dont need...............
Claire xx
Paul TigerB6
posted on 10/5/08 at 06:49 PM Reply With Quote
Possibly blown the head gasket??? If it was burning oil i'd expect the smoke to be blue.
[Edited on 10/5/08 by Paul TigerB6]
clairetoo
posted on 10/5/08 at 06:52 PM Reply With Quote
Might be why it was on ebay for just £100
Claire xx
JAG
posted on 10/5/08 at 06:58 PM Reply With Quote
White smoke is usually a water/anti-freeze leak into the combustion chambers.
Might just be the head gasket as Paul says.
Justin
Paul TigerB6
posted on 10/5/08 at 07:01 PM Reply With Quote
Ah right. Well hopefully the head isnt warped if it is a head gasket!!! Can you do a compression test on it at all as BigWasa suggests?? Worth checking the oil for coolant / coolant for oil etc. Any odour apparent to the smoke??
big_wasa
posted on 10/5/08 at 07:10 PM Reply With Quote
I asumed it to be the big old v6
You can buy a dye testing kit that will tell if there are exhaust gasses in the coolant.
Are you loosing any coolant ?
What gearbox are using on the back of that ?
clairetoo
posted on 10/5/08 at 07:12 PM Reply With Quote
Unfortunately I dont own a compression tester , if I have to remove the heads......£60 for top end set , then theres all those hours of porting and polishing .............
I`m hoping to be off to Laon in two weeks time for the historic car festival.........
Claire xx
clairetoo
posted on 10/5/08 at 07:16 PM Reply With Quote
Its on an Mx5 gearbox via an adaptor plate and on-off ally flywheel.............it looked easy when I started but turned into a bit of a mission !
It runs well enough to rev clean ( OMG it sounds awesome ! ) , but I havnt driven it yet - that joy will come next week if I can get it through an MOT .
Claire xx
posted on 10/5/08 at 07:19 PM Reply With Quote
Wouldn't have thought a head gasket failure would cause a rise in C.O. I would be looking at overfueling on the bank that is high, possibly faulty injector? Is the cooling system installed and filled? if it is, as big wasa says the dye testing kit would tell if it is head gasket in a few seconds and cheaper than a head set although if it is head gasket you would have to buy one.
stevec
posted on 10/5/08 at 07:23 PM Reply With Quote
Agreed, Co% is burnt fuel, sounds rich to me Have a good look at the fueling on that bank.
Steve.
clairetoo
posted on 10/5/08 at 07:26 PM Reply With Quote
I`ll check out a dye testinc kit monday - I can swap injectors around in the morning , that should soon show me if theres a faulty one .
Thanks for the tip - I didnt think of that !
Claire xx
posted on 10/5/08 at 07:30 PM Reply With Quote
Could be cos your blonde
clairetoo
posted on 10/5/08 at 07:32 PM Reply With Quote
Claire xx
posted on 10/5/08 at 09:19 PM Reply With Quote
A compression tester is a quite useful bit of kit......
