omega0684
| posted on 13/5/08 at 07:41 PM |
megasquirt help
evening all,
i currently have pinto set up with dizzy but want to change to edis and megasquirt,
can some please explain to me what is involved in the conversion, i have edis module, coil pack and vr sensor with 36-1 wheel.
does anyone know of any threads or websites that explain what modifications need to be made to the dizzy etc
all help is welcome
Alex
matt_claydon
| posted on 13/5/08 at 07:53 PM |
By the sound of it you mean 'Megajolt' - MS is a full fuel injection system whereas MJ is just a mappable ignition controller. Loads of
guys on here got MJ on Pintos so I'm sure someone will be along shortly...
[Edited on 13/5/08 by matt_claydon]
omega0684
| posted on 13/5/08 at 08:09 PM |
you can have mega jolt and megasquirt on the motor cant you?
paulf
| posted on 13/5/08 at 08:36 PM |
Yes you can that is how mine is set up, but what you require is megasquirt and edis set up info as you already have megasquirt,Try the Extra.efi.co.uk
site or a search on the megasquirt forums until you find the set up info.Basically you need to connect the pip and saw signals from the Edis to the
megasquirt via the 37 pin connector and then set the megasquirt to run Edis.You will also need the megasqirt and spark firmware installed if its not
already.
Paul
Arnie
| posted on 13/5/08 at 09:36 PM |
Just recently moved over to a megajolt. Fairly easy to install and set up. There is a good guide on the Megajolt site.
http://www.autosportlabs.net/index.php?title=MegaJolt_Lite_Jr._Users_Welcome
or
Regards,
Arnie.
Jenko
| posted on 15/5/08 at 05:53 PM |
Megasquirt = Ignition and fuel injection
Megajolt = Ignition only
So you need to decide, do you want to change to full fuel injection?.
FYI, installing Megasquirt requires you to install a new high pressure fuel sysem, and a load of sensors to the engine - It's a far more
involved process.
If you are happy with Carbs, then just go for the Megajolt option..For this you will need to install a VR sensor / trigger wheel, Throttle postiion
sensor, the MJ unit, EDIS and edis coil pack......
matt_claydon
| posted on 15/5/08 at 06:12 PM |
Ah, didn't realise but it sounds like you are already running Megasquirst for the fuel side. You need to switch to running
"Megasquirt' n' Spark - Extra" also known as "MSExtra" software and make some minor hardware changes to hook up
the EDIS.
Everything you need to know is here:
http://www.msextra.com/manuals/MS_Extra_Manual_Index.htm
matt_claydon
| posted on 15/5/08 at 06:13 PM |
Oh yeah, and to answer part of your question - the Dizzy is completely redundant although you need to leave it in as the oil pump is driven from the
base. Some cut the top off but I didn't bother, I can't see it with the bonnet on!
