swalf3
| posted on 14/5/08 at 07:39 PM |
06 R1 can't start
Engine was running,during a drive engine cut.When ignition turned on pump does not prime.All start and pump relays checked.With pump running still
will not start.When engine is spun it makes sounds as though trying to start.What can I check next? Thanks Winston
CRAIGR
| posted on 14/5/08 at 07:46 PM |
Tilt sensor maybe??
swalf3
| posted on 14/5/08 at 07:55 PM |
Chris,the engine is solid bolted to mounts which are in turn bolted to chassis.Do I still need an earth strap?Winston
Davey D
| posted on 14/5/08 at 09:57 PM |
Are you using the standard R1 clocks? if so are there any ECU codes?
Has you wiring come lose from the side stand wire?
Have you checked the fuses in the starter relay, as there are 2 in there.
Have you tried holding the starter button down to see if it starts, and runs whilst the button is held in
nstrug
| posted on 14/5/08 at 09:59 PM |
If the pump is not priming, how are you then running the pump?
I only know the R1 5PW (02-03) but I imagine that the later engines have a similar cutout relay.
The relay will only allow the engine to start (i.e. enable the fuel pump relay and ignition) if the following conditions are met:
1. If sidestand is down, gearbox must be in neutral
2. If sidestand is up, either engine must be in neutral OR clutch must be pulled in
On a car, the sidestand switch and clutch switch are shorted so I would suspect the neutral switch.
You should also check that you have spark and fuel the usual ways.
Nick
r1 locost
posted on 15/5/08 at 07:57 AM |
sounds like the tilt switch to me. easy way to find out remove airbox or fillter put a small amount of fuel in the tb's then try and start it if
she fires its just fuel problem
