bill132hotrod
posted on 19/5/08 at 06:46 PM |
Homemade airbox for motorbike carbs
Hi guys can anyone share some idears as to how to make an airbox to fit on a set of 1100 ZZR carbs and fit under the bonnett on a 7 style car pictures
would be a great help. Cheers BILL.
PERSEVERANCE is the word of the week. Stick with it the results are SWEET.
Triton
posted on 19/5/08 at 06:55 PM |
Here you go
www.tritonraceseats.com
www.hairyhedgehog.com
jacko
posted on 19/5/08 at 07:00 PM |
How about like this but with a pipe at the rear to a remote filter
[img][/img]
r1_pete
posted on 19/5/08 at 07:01 PM |
Was once an ally race can:
bill132hotrod
posted on 19/5/08 at 07:13 PM |
Airbox
Hi Pete thats the sort of idear i've got but how have you fitted the can to the base plate?. Cheers BILL
paulmw
posted on 19/5/08 at 07:33 PM |
Not carbed but my airbox anyway
r1_pete
Hi, the backplate is bent up top and bottom to the angle needed to meet the alloy cover, then I welded another strip alongside to forma channel into
which the cover fits, then the two end plates push on, eventually two lengths of threaded rod will be used to hold the lot together.
This pic is huge but you can see the slot arangement.
givemethebighammer
posted on 19/5/08 at 07:40 PM |
Mine doesn't fit under my bonnet but there are some pics of it in this thread
http://www.locostbuilders.co.uk/viewthread.php?tid=54014&page=1
posted on 19/5/08 at 08:00 PM |
Mine fits under the bonnet and it's made from carbon fibre
DIY styleeeeeee
Cut down the standard ST1100 airbox, cut one end off it, glued on a plate onto the cut end, then made up a carbon fibre plenum thingy that goes
between the ST airbox and the ali tube connecting to the filter. Carved the plenum out of polystyrene, sanded it smooth, slathered it in epoxied
carbon, carved out 99% of the polystyrene then disolved the rest out with petrol. Walloped a plate on the end to bolt onto the airbox plate and happy
days all round....
and yes I know my garage is (was) very messy....
posted on 19/5/08 at 08:04 PM |
Here's mine - more a filter box than an airbox, on CBR600 carbs.
bill132hotrod
posted on 19/5/08 at 08:09 PM |
airbox
Hi David that one is very smart, how does it fit to the carbs Cheers BILL
posted on 19/5/08 at 08:18 PM |
Bill,
I was fortunate in that I got the original bike airbox with my carbs - this had the mounting rubbers that go between the carb mouths and the filter
back-plate. Having the right kit always makes life much easier!
If you go to my website (www link below) and open the 'bike carbs' link, then the 'Fitting to the engine' link, you'll
see some details half-way down the page.
clairetoo
posted on 19/5/08 at 08:25 PM |
A way I found of gaining space was to use the flat underside of my bonnet bulge as the top of the airbox .
airbox
I know their not bike carbs , but they are at least bike throttle bodies
Its cuz I is blond , innit
Claire xx
Will weld for food......
amalyos
posted on 19/5/08 at 08:53 PM |
Mines homemade for R1 Carbs.
I used the bike airbox, cut the mounting clamp area out, and sealed it into an aluminium box.
The carbon airfilter is from Car Builders Solution.
Had it on the rolling road, and only had to increase the main jets. No Dyno jet kit required. Very Happy
http://stevembuild.blogspot.com
robbydee
posted on 19/5/08 at 08:57 PM |
http://www.locostbuilders.co.uk/viewthread.php?tid=88800
this thread has pics of my pipercross 600 air box fitted to r1 carbs on a pinto all under the bonnet.
lsdweb
posted on 19/5/08 at 09:50 PM |
Folded aluminium, then rivetted and seled with ali duct tape.
locost and light!
R1 Airbox
It fits under my 'bonnet' :-)
[Edited on 19/5/08 by lsdweb]
