Author: Subject: Carb balancing question
Mr Whippy
posted on 20/5/08 at 11:29 AM Reply With Quote
Ok so here’s a stupid question…
There I have a couple of twin Webbers (40 DCOE 18) on the pinto and I’m suppose to balance them right, fair enough makes sense I’d want one carb to be opening the same amount as the other one, but for each carb can I adjust the individual barrels relative to each other, don’t see how, thought there might be an air bleed screw perhaps but don’t see one off those. No adjustment of the butterflies either, nope don’t see at all what I’m meant to be fiddling with.
Am I wrong here?
RichardK
posted on 20/5/08 at 11:53 AM Reply With Quote
Haven't got dcoe but have book marked this page for some reason, there is a picture on there that does say when the throttle adjustment screw is etc.
LINKY
Rich
Gallery updated 11/01/2011
melly-g
posted on 20/5/08 at 12:08 PM Reply With Quote
No you can`t balance each individual choke , you balance 1 choke on each carb to ensure both carbs are breathing the same. If that makes sense! you should be able to adjust the carbs with the linkage between them, then set them up with the idle mixture screws on each choke.
Mr Whippy
posted on 20/5/08 at 01:17 PM Reply With Quote
cheers for that guys
that setting up instructions are great, what a big help
[Edited on 20/5/08 by Mr Whippy]
dave r
posted on 20/5/08 at 06:40 PM Reply With Quote
think i may have a haynes manual for dcoe's
