r1_pete
| posted on 20/5/08 at 02:58 PM |
Temperature sender
I remember having a car which used a small brass temperature sender 1/8 NPT, which, instead of a regular spade or bullet conector, it had a brass disc
which took the spade connector sideways, and allowed it to rotate 360 to connect in any direction.
Anyone know of such a beast? it would solve a little problem for me and the raceline water rail....
Cheers.
Pete.
DaveFJ
| posted on 20/5/08 at 03:09 PM |
I bought the exact item the other day from Jayar in Ipswich
It was an intermotor part.. like this....
link
but I can't guarantee it is that one - the site doesn't give the thread size....
HTH
[Edited on 20-5-08 by DaveFJ]
Dave
rallyingden
| posted on 20/5/08 at 03:11 PM |
Try this place but you will have to email for pic's
Link
RD
big_wasa
| posted on 20/5/08 at 03:30 PM |
Just being nosey, is it for the ecu or your gauges ?
I ask as I am not 100% I have the correct one for my ecu.......
r1_pete
| posted on 20/5/08 at 03:36 PM |
Thanks for the responses guys, will check out the leads...
Its for my temperature gauge, are you using a megasquirt, cos I understand they can be calibrated to match sender resistances....
Rgds.
Pete
DaveFJ
| posted on 20/5/08 at 03:43 PM |
I am using mine for the signal to megasquirt but I am not entirely sure it is accurate enough.....
once the engine is warmed up megatune shows a constant 102 degrees at the engine regardless of the watertemp shown on the guage which can vary from 90
- 120 degrees!!!
(and yes I have calibrated the sensor in megatherm properly!)
that being said - if you follow through on my link above you can see that those sensors are described as 'engine management sensor'....
Dave
big_wasa
| posted on 20/5/08 at 04:12 PM |
Its for my Dunnell ecu, Dunnell say use the standard sensor ?
The water rail has the 1/8 thread .
There are two sensors in the standard stat housing
1/8
3/8
Posts on here point to the 3/8 sensor being for the ecu.
adithorp
| posted on 20/5/08 at 06:48 PM |
Mk2 Cavaliers and early Astras and Novas were like that. Not sure of the thread and some aftermarket sensors for them were a normal 6mm spade
connector.
adrian
:{THC}:YosamiteSam
| posted on 21/5/08 at 02:33 PM |
standard ford thread that one - by the way - i have just spoken to dunnels this afternoon they didnt think the water rails were very good in helping
cooling - but i didnt go into it - i have the dunnell set up too on mine - used a VDO gauge with standard ford sensor came with it..
