Author: Subject: Type nine quickshift
Andy D
posted on 20/5/08 at 08:12 PM Reply With Quote
Has anyone fitted one of Rally design's type nine quickshifts. There seems to be three kits available. "Competition", "Quiet", and a full Competition lever.
From the photos on the website, I cant figure out what the bits and bobs do. I know the object of the exercise is to raise the lever pivot point.. but what's the lever "extension" for? and why no extension with the "quiet" kit??
Rally Design quickshifts
mitch2b
posted on 20/5/08 at 08:22 PM Reply With Quote
locost version here,
http://hometown.aol.com/dvandrews/quick.htm
[Edited on 20/5/08 by mitch2b]
Andy D
posted on 20/5/08 at 08:31 PM Reply With Quote
Yes, I know about that one.. It's just at £11 for the cheaper kit option, I thought it wasn't worth bodging up my present lever, with the risk of knackering it completely.
Would also be interested to hear from anyone who's done the Locost mod.
posted on 20/5/08 at 08:43 PM Reply With Quote
If you look at my website you'll see how I combined Dave Andrews' 'quickshift' with my design for a gear-lever extender to move the stick 5 or 6 inches further back.
No detailed drawings, but not too hard to work out. Several people on this forum have successfully made a copy.
If you don't need the extension (ooer, missus!) then I can vouch for Dave Andrews' modification - it really does work. You might like to try it on a stick from the scrappy though - if you're successful with the mod on the scrappy stick, then you can sell the original one - they have value, these days.
BTW: Don't try to shift a type 9 box too fast - they don't like it and may wear out prematurely if you're too harsh.
HTH
triumphdave
Hi Andy,
I have done the locost mod to reduce the travel of the lever when I changed my dash,works well.Just less movement and a bit stiffer.
Humbug
posted on 20/5/08 at 09:08 PM Reply With Quote
I used the Dave Andrews locost method - works a treat
mitch2b
posted on 21/5/08 at 05:31 AM Reply With Quote
me too, i know quite a few which have done it without problems,
Mitch
Andy D
posted on 21/5/08 at 03:11 PM Reply With Quote
That's one of my main concerns. I can allready beat the synchromesh with a "slow" shift, so is it all worth it..
posted on 21/5/08 at 03:14 PM Reply With Quote
The biggest benefit is that it'll stop you cracking your knuckles on the dash!
It's not a matter of beating the synchro though - too-fast gearchanges done too often can result in broken baulk rings.
[Edited on 21/5/08 by David Jenkins]
Andy D
posted on 21/5/08 at 03:21 PM Reply With Quote
No problems with the dash / knuckle thing.. I get a bit of a bang changing up quickly from 2nd to 3rd I think, usually when changing at 7000rpm. I dont think the standard gearbox likes that treatment, so the plan is to change it for an uprated BGH or similar, when it expires.
DarrenW
posted on 22/5/08 at 01:24 PM Reply With Quote
I got my quickshift kit from Mac#1. Your welcome to try it if you want. No idea how it compares to standard - i fitted it when building so nowt to compare to.
Andy D
posted on 22/5/08 at 03:13 PM Reply With Quote
May take you up on that offer Darren. We're off down south for the weekend, will give you a shout next week sometime if thats OK. BTW, How much is the Mac1 version?
