Author: Subject: Zetec crank and con rod
Micael
posted on 21/5/08 at 09:16 PM Reply With Quote
Does anyone know if the con rods and crank are interchangable between 1.8 and 2.0 silver tops.
I have had a bearing failure in my 2.0 which damage the crank and one rod. I have a 1.8 crank and con rod lying in the garage so i thinking of using them.
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23 2009
madteg
posted on 21/5/08 at 09:23 PM Reply With Quote
con rod
Was you running arp rod bolts, as i had the same thing and found out this is a week spot on the zetec.
I thing that you can interchange them as piston size is different.
[Edited on 21/5/08 by madteg]
Micael
posted on 21/5/08 at 09:27 PM Reply With Quote
nope, no arp bolts
I will however buy a set now
Micael Moose Åman
zetec
posted on 22/5/08 at 05:05 AM Reply With Quote
What was your rev limit? It's the rpm which causes them to fail normally. I have mine set to 7200 and mine have been OK. Read about a bloke with a turbo fitted and still on standard bolts all OK.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
posted on 22/5/08 at 09:15 AM Reply With Quote
A local engine builder (who has a very good reputation) reckons he's never had Zetec let go up to 8000RPM with heavy duty rod bolts.
Micael
posted on 22/5/08 at 12:20 PM Reply With Quote
According to my megasquirt logs (I was actually logging when i blew the engine) so was the max rpm 6600.
Micael Moose Åman
Micael
posted on 23/5/08 at 11:57 AM Reply With Quote
Last night i removed the pistons. On one of the pistons a big chunk of metal fell off. it came form between the first and the second ring.
I have no sign of "detonation" marks on the piston top.
The head is skimmed 1 mm but as i heard it should be ok.
The saga continues
[Edited on 23/5/08 by Micael]
Micael Moose Åman
Schrodinger
posted on 23/5/08 at 07:54 PM Reply With Quote
If you use ARP rod bolts check to see if they match the caps as the caps are square and the bolts have chamfers in the corner of the head so the caps need machining to tighten properly.
Keith
Aviemore
posted on 23/5/08 at 11:32 PM Reply With Quote
There were no detonation marks on the crown of this piston either, apart from the slightly melted top ring land...
Micael
posted on 24/5/08 at 06:35 AM Reply With Quote
ouch......
I will take some pics off the piston today. It looks similar to yours.....
Micael Moose Åman
Micael
posted on 26/5/08 at 07:37 AM Reply With Quote
..........[img]http://locostbuilders.co.uk/upload/a749069-2008-05-26 001 [1024x768].JPG[/img]
Micael Moose Åman
