nathanharris1987
| posted on 30/5/08 at 12:35 PM |
Zetec Thermostat Housing temp sender thread
Hello!
Could any one tell me what the thread size is for the big hole in top of the zetec thermo housing.
For blanking off purposes, I know its 16 dia but not a standard thread?
Nath
the_fbi
| posted on 30/5/08 at 01:36 PM |
Apologies as this will only help you find the information yourself, but thats for the rad fan switch not the temp sender.
[Edited on 30/5/08 by the_fbi]
nathanharris1987
| posted on 30/5/08 at 01:46 PM |
do you actually work for the fbi?
stevebubs
| posted on 30/5/08 at 03:43 PM |
Yes - it is a standard thread. I got a blanking plug from think auto.
stevebubs
| posted on 30/5/08 at 03:45 PM |
PS 1.5mm pitch rings a bell, but not 100% sure...
:{THC}:YosamiteSam
| posted on 30/5/08 at 03:58 PM |
are you sure? the one on mine is for the ecu temp sender in the same place there - unless its been changed
big_wasa
| posted on 30/5/08 at 04:22 PM |
3/8 ntp
edit
so thats Npt then
[Edited on 30/5/08 by big_wasa]
big_wasa
| posted on 30/5/08 at 04:24 PM |
Rad fan is controled by the ecu, ecu uses that sensor.
stevebubs
| posted on 30/5/08 at 04:43 PM |
CLicky
Mark G
| posted on 30/5/08 at 04:54 PM |
The hole shown is for the ecu temp sensor.
There is another hole underneath for the cluster temp sensor
There is a Thermostatic switch in the top hose from the rad to the thermostat for the rad fan.
I've got an old sensor thats no good if you just want to block it up. You're more than welcome to it.
[Edited on 30/5/08 by Mark G]
the_fbi
| posted on 30/5/08 at 07:02 PM |
I stand corrected.
Got confused as I've got a silvertop stat housing on my blacktop with an unused top sensor, and a rad fan switch tied up to the battery as Ford
decided it would be better to have the fan controlled by ambient air rather than water in the cooling system.
nathanharris1987
| posted on 31/5/08 at 12:17 PM |
rad fan switch ive got actually in the rad, another temp sender is the little mejobby going upward and in at an angle closest to the starter.
standard thread bolt doesnt work, like it stops a complete turn in, dont want to give it any va-va-voom incase the threads are crosssd
I give up trying to find the right bolt that will blank it and jus skiv another sender from scrappy and leave it hanging.
Baw bags.
