Author: Subject: 2.0 flywheel identification
philtvr
posted on 1/6/08 at 05:38 PM Reply With Quote
How can you visually tell the differnece between a 2.0 zetec flywheel and a 1.8 flywheel. I ahve been given a couple of flywheels and need to know which is 2.0.
thanks in advance for your help.
posted on 1/6/08 at 05:52 PM Reply With Quote
2.0 is hefty with a raised metal rim and the 1.8 is much lighter with a flat clutch mounting face.
JohnN
posted on 1/6/08 at 08:05 PM Reply With Quote
Do you want the 1.8 flywheel?
Werner Van Loock
posted on 1/6/08 at 08:27 PM Reply With Quote
here you go:
http://www.clubstylus.be
philtvr
posted on 1/6/08 at 08:41 PM Reply With Quote
excellent, thanks for the help, the westfield manual says to use the 2.0 flywheel, is there a reason for this if its the heavier one????
Werner Van Loock
posted on 2/6/08 at 07:03 AM Reply With Quote
Benefit of the 2.0 flywheel is that you can use the standard cluthplate and pressure plate of the 2.0 mondeo as it has the correct splines and all. If using the 1.8 escort flywheel you will have to get different clutch parts from different cars wich is sometimes difficult to get as most shops only sell full kits.
Don't forget to add a spigot bearing. You can get it from ford if you're lucky otherwise a single sided dust sealed needle bearing : 21 x 15mm x 18mm bearing INA HK1518RS (is the one i used)
philtvr
posted on 2/6/08 at 07:38 AM Reply With Quote
thanks again for all the help,much appreciated.
