Author: Subject: Type 9 spigot bearing ID
bilbo
posted on 1/6/08 at 06:27 PM Reply With Quote
Can anyone confirm for me the internal diameter of the standard ford spigot bearing for a type-9 gearbox. I've measured the end of the input shaft on the box and it appears to be 15mm, but I don't have any vernier calipers or similar to be absolutly sure it's not a similar imperial size?
Many thanks,
Bill
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
owelly
posted on 1/6/08 at 06:30 PM Reply With Quote
15mm I/D and 22.8 O/D seems to ring a bell.
http://www.ppcmag.co.uk
miikae
posted on 1/6/08 at 06:42 PM Reply With Quote
The bearing number is a F-33126 Z
Mike
If it can be done it i will be done .
bilbo
posted on 1/6/08 at 06:53 PM Reply With Quote
Mike
Unfortunatly the standard part wont work in this instance. coozer and I are in the process of trying to find bearings to fit the crank of the Rover T16 engine. I just needed to confirm the ID required.
owelly
posted on 1/6/08 at 09:07 PM Reply With Quote
I used a needle roller bearing when I wanted to fit the type 9 input shaft into my Alfa flywheel/crank orifice. Is was about £10 from the local BSL Brammer place.
