philtvr
| posted on 2/6/08 at 07:40 AM |
Gearbox to engine bolts
I am bolting an MT75 to a 2.0 zetec, i need to get the bolts to connect the two. Can i get eithere sierra bolts or mondeo bolts or do i need to get
the sierra ones dut to length. Thanks in advance.
mad4x4
| posted on 2/6/08 at 11:16 AM |
Should just be M10 bolts IIRC make sure they are grade 8.8 or higher
Scot's do it better in Kilts.
Mix
| posted on 2/6/08 at 03:19 PM |
Hi
At the risk of getting shot down in flames I'd suggest that any bolt of the correct size and length would be suitable, the bell housing to block
joint does not experience forces which would require the use of any above spec bolts. At the end of the day the easiest way to get bolts is probably
to aquire them from a donor so this question shouldn't arise but if I had to ues B&Q specials for this application it wouldn't concern
me as long as they were torqued and threadlocked.
Regards Mick
PS I'm fully aware of the relationship between torque and streach/grip but agian IMO it is not significant in this application
