Author: Subject: Getting the blummin cambelt pulley off a pinto crank
ed_crouch
posted on 2/12/03 at 03:38 PM Reply With Quote
How is this done?? do i need a special slimline pair of pullers?? When i took the crank out, i just took the ally housing off the block with it, but now want to take it apart for cleaning.
Ed.
DaveFJ
posted on 2/12/03 at 04:17 PM Reply With Quote
Get hold of a decent puller and don't be tempted to 'help it along with a gentle tap' it's made of quite soft metal and deforms easily..... I speak from experience !
Anyone got a spare pulley for a 2l pinto they don't want ??
Dave
James
posted on 2/12/03 at 07:37 PM Reply With Quote
Gotta agree with proto- a hub puller's the way to go.
Mine was a fiver from a show and is used a lot.
Anybody got *two* spare pulley's?
James
bob
posted on 2/12/03 at 07:43 PM Reply With Quote
James
I'm pretty sure i have one cam belt pullley thats not in too bad condition
If thats what you want i'll bring it too the Hill on sunday.
bob
posted on 2/12/03 at 08:05 PM Reply With Quote
James
If you dont need it i'll post it off to protofj.
jollygreengiant
posted on 2/12/03 at 08:16 PM Reply With Quote
on the front of the pulley are two (or 4) 8 x 1.25 mm threaded holes, leave the centre bolt in but loose, fit plate to front of pulley with 2 x 8mm bolts & in centre of plate you need a threaded hole to take a 10 x 1.5 mm bolt. this when screwed in (the 10 x1.5 mm bolt) will push against pulley bolt and hey presto the pulley can be removed in seconds (ish).
Enjoy
P.S. you should be able to work out basic dimensions from the above.
DaveFJ
posted on 3/12/03 at 09:08 AM Reply With Quote
Thats what I tried JGG - but still got tempted and 'assisted' it with a 'variable pressure applicator'
Dave
