tcr
posted on 8/6/08 at 07:37 PM |
GBS BIKE CARBS FITTED
Finally got to run the car after fitting the bike carbs from gbs (robinhood) straight from the box apart from having the manifold coated and only
adjusted idle
bike carb vid
MK MIDI ZX10R
http://www.facebook.com/media/set/?set=a.4393256076054.2182513.1427988207&type=1&l=64c91c3c17
why isnt anything simple!!!
torquetune.co.uk
nrpexhausts.co.uk
hellbent345
| posted on 8/6/08 at 07:51 PM |
now thats a tasty sounding rasp lovely looking things
ragindave
| posted on 8/6/08 at 10:26 PM |
Sounds superb are these running with out any help?
What does it drive like through the rev range.
tcr
| posted on 8/6/08 at 10:38 PM |
first press of the button without any throttle on it kicked straight up anyone with twin carbs will know you have to pump first then hold throttle on
till it stops spitting and farting plus its a totaly different exhaust note
the pick up is emense we've been running 45's but when i ran it up the road it took me by surprise the thing exploded like a rocket i cant
praise the carbs enough but ive got to sort another shut off spring for the race regs if anyone has any ideas
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
ragindave
| posted on 8/6/08 at 11:05 PM |
No electronic management running these?
tcr
| posted on 8/6/08 at 11:22 PM |
nope just right foot+vpower fuel+air=no hassle fun
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
DavidW
| posted on 9/6/08 at 06:10 AM |
I was thinking of getting a set of these. What did you get the manifold coated in?
tcr
| posted on 9/6/08 at 07:16 AM |
just powder coated black although it did need 5mins with the dye grinder inside it first
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
jake_truck
| posted on 9/6/08 at 09:11 AM |
Hi
which fuel pump are you using?
have you used a regulator?
really fancy a set of these!
regards
john
tcr
| posted on 9/6/08 at 01:51 PM |
quote: Originally posted by jake_truck
Hi
regards
john
hi john we using a pierburg cant remember what model but its electric/mechanical runs a constant 3psi so no regulator needed £75
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
