rpm
| posted on 9/6/08 at 05:27 PM |
best fit throttle bodies?
just started looking at the engine for my new project,( vauxhall c20xe) i want to fit some bike throttle bodies, question is which would be the best/
nearest fit for this engine? i need an inlet diameter of 42mm minimum on the engine side and believe gsxr 1000 are about that size i also have a set
of hyabusa ones available but don't know what size they are . anyone know which are easiest to respace/which will work best?
andrew-theasby
| posted on 9/6/08 at 05:50 PM |
Blackbird ones were the closest i found, there sat next to my computer at home so if you need any dimensions, u2u me and ill let you know next time im
on.
rpm
| posted on 9/6/08 at 06:00 PM |
u2u sent
