se7ensport
| posted on 13/6/08 at 01:24 PM |
Brazing in lambda bung
basically will this work or is it likely to melt the braze out once running?
Alex
Werner Van Loock
| posted on 13/6/08 at 01:39 PM |
moving to the next step with the vems?
http://www.clubstylus.be
will121
| posted on 13/6/08 at 01:40 PM |
how far are you placing it down the manifold? if after the collector or 750mm would expect it be ok, but would think it be better welded.
| posted on 13/6/08 at 01:49 PM |
manifold distance from engine will make that decision for you as well as melting point of solder.
I was playing with IR termometer just a coupld days ago.
crossflow with 4-2-1 exhasut.
temp at head 300 C
temp at pipe where it exits through body 50 C
temp at tail pipe 30 C
these temperature will be higher if engine is driven hard but then there is air cooling.
se7ensport
| posted on 13/6/08 at 01:52 PM |
Indeed Werner, I'm planning on going to injection over the next few weeks, just a few odds and sods to sort first.
iank
| posted on 13/6/08 at 01:53 PM |
Melting point of the filler metal is going to be the decider. 450 degrees C is about the lowest going up to over 1000oC IIRC
Anonymous
twybrow
| posted on 13/6/08 at 01:54 PM |
Were you measuring stainless with an IR thermometer? If so, the readings will be tosh, due to the emissivity (shinyness!) of the tube. Put some
masking tape on, coloured black with a pen. If not - ignore me!
se7ensport
| posted on 13/6/08 at 01:55 PM |
Planned to put it approx 100 cm from head, after the 4-1 collector to ensure I'm getting an accurate reading from all cylinders.
i'm thinking that I should just do it properly and weld it, its just that I have brazing gear readily to hand....
| posted on 13/6/08 at 02:03 PM |
indeed - so ignore the last 2 readings although when I grabbed the tail piece, it was not that hot so 30 was reaonable I thought.
Bluemoon
| posted on 13/6/08 at 02:21 PM |
From what I recall, Stainless steel is actually quite black in the infrared, I expect the readings at not to bad.. Shiny surfaces in the visible are
not always shiny in the infrared...
Dan
stevebubs
| posted on 13/6/08 at 02:53 PM |
Just pop round to your local welder...will be cheaper than having the sensor damaged by brazing filler....
bikenuts
| posted on 20/6/08 at 12:27 PM |
Just after the collector can be a bit of a hot spot - so I'd weld. To be honest anywhere that's hot enough to keep a lamda sensor nice and
clean is likly to be a bit hot for braze.
