bracey
| posted on 15/6/08 at 06:02 PM |
ecotec to getrag box
are the above compatable ??thinking of updating my power plant and would like to use the same box ,currently got opel manta engine and box
cheers
richard
philw
| posted on 15/6/08 at 06:08 PM |
A big Yes, thats the same set up as i had in mine, you need to use the manta flywheel and clutch obviously, also you will need to drill the flywheel
bolt holes as they are smaller on the manta, if you need to know anything else just ask
[Edited on 15/6/08 by philw]
Must try harder
