matt.c
posted on 16/6/08 at 08:54 PM |
Fuel filter?
Is there any difference between a fuel filter which has come from an injected engine and one from a carbed engine?
Im using it as a pre pump filter.
Many thanks locosters.
| posted on 16/6/08 at 08:57 PM |
Injection filters are usually pretty high flow and often post-filter so they are usually built to handle high pressure.
If you're using it pre-pump it won't be under high pressure so as long as it can flow sufficiently it's much of a muchness...
sebastiaan
| posted on 17/6/08 at 01:54 PM |
Pre-pump needs to flow sufficiently. For a cheap source, see
this link
Sebastiaan
