focijohn
| posted on 17/6/08 at 08:36 PM |
TB's or Carbs?
Evening all,
as per the subject. I am thinking of using a ST 2.0 zetec (pre 95) along with some mild cams, and am going to challenge myself and put together a MS
brain.
Which would be better TB's or carbs? Was going to use bike bits seeing as this seems to keep cost relatively low. Im not sure weather it would
be worth using a BT instead in which case TB's seems to be the only choice because of the 02 sensor (i will stand corrected!).
Which bits and bobs would be needed apart from the manifold and pumps?
John
Anyone going slower than you is an idiot. Anyone going faster than you is a maniac.
Too many targets but too few bullets.
clairetoo
| posted on 17/6/08 at 08:56 PM |
I'd go for TB's - if you can make a manifold and any other bit's they can be cheap to do (mine came to £65 - for six ! )
Edit - and another £25 for fuel rail material , and £10 for injectors........
[Edited on 17/6/08 by clairetoo]
Its cuz I is blond , innit
Claire xx
Will weld for food......
focijohn
| posted on 17/6/08 at 09:21 PM |
what size for the TB's and what injectors do u use?
| posted on 18/6/08 at 11:59 AM |
Apparently the Zetec will accept a Rover T16 inlet manifold if an adaptor plate is used --- was covered a while back.
