tks
| posted on 18/6/08 at 08:52 PM |
POLO
rad hi people..
being a BEC and thinking to losse some weight i want to change my copper rad from a Fiat 127 for an polo one but cant see an easy way to mount it on a
velocity XT any one ideaas/ tips how to do it??
regards,
Tks
omega0684
| posted on 18/6/08 at 09:04 PM |
do you have the polo rad, i have one spare if you need it,
i mounted mine on a small rail across the front and then tapped the top holes and screwed them into brackets that were rivetted to the chassis.
| posted on 18/6/08 at 09:14 PM |
Ditto
A bar or rail is a nice idea. I just used four bits of bar (one into each mount point on the rad). Kind of like a X mounting if you see what I mean.
Works well.
ChrisGamlin
| posted on 18/6/08 at 10:05 PM |
I used strips of alu plate to mount mine . You can see one mounting point on the top rail in this pic
  Top hose plumbing
There's two more mounts coming off the downtubes picking up on the lower mounting holes on the rad, and being in the vertical plane rather than
horizontal like the top ones, it holds it all very rigidly even with the additional weight of the oil cooler hanging off the front.
[Edited on 18/6/08 by ChrisGamlin]
bob
| posted on 18/6/08 at 10:40 PM |
Ali strips and angle to support pegs on bottom then easy brackets for top and M6 bolts threaded into top position holes.
bob
| posted on 18/6/08 at 10:41 PM |
top rad
bob
| posted on 18/6/08 at 10:42 PM |
other side
lsdweb
| posted on 19/6/08 at 09:18 AM |
Not a '7' but a Polo rad in my single seater. I only have one mounting point per side so I have an ali bracket coming off both the rad
mounting points.
Sorry but this is the best photo I can get without taking the engine out!
  Polo Rad in Swift
tks
| posted on 19/6/08 at 10:55 AM |
quote: Originally posted by bob
other side
nice one guys...
bob how did you blanked off the top hole? whats it in there (the top 8mm e outlet)
Sorry, i have already one...65euros new..
(from international radiators)
Tks
[Edited on 19/6/08 by tks]
Macbeast
| posted on 19/6/08 at 11:28 AM |
Cheap and nasty solution
  Rad mount
  Rad mount 2
The triangular brackets are off the shelf from DIY store.
To close off the 8mm radiator pipe, I slid on a piece of 8mm petrol pipe with a hose clip and then screwed an 8mm screw into thye end
bob
| posted on 19/6/08 at 12:25 PM |
M3 or M4 bolt self tapped into the 8mm bleed on top of rad, handy when filling rad for 1st time to loose the air lock.
I did try the macbeast way 1st but the nose cone is a tight fit so the bolt worked fine.
ned
| posted on 19/6/08 at 12:34 PM |
BMF has a number of pics in his archive showing the standard polo rad mounts on his velocity chassis..
Ned.
beware, I've got yellow skin
