Author: Subject: IT'S ALIVE
scutter
posted on 19/6/08 at 08:34 PM Reply With Quote
IT'S ALIVE
After much messing about with the edis and slight lack of fuel problem (supply and return work much better the correct way around) the MS powered Zetec fired up on the button
HERE is a link to a very dull video.
Dead chuffed now, just got to get the Easytherm sorted as the engine thinks it's coolant temp is -35 on start up
ATB Dan.
[Edited on 19/6/08 by scutter]
big_wasa
posted on 19/6/08 at 08:37 PM Reply With Quote
clairetoo
posted on 19/6/08 at 08:38 PM Reply With Quote
Well done !
And good luck with easytherm - I gave up and had a good friend re-work the ECU to get the temp's reading right after I confused it severely trying to make easytherm work
Its cuz I is blond , innit
Claire xx
Will weld for food......
scutter
posted on 19/6/08 at 08:40 PM Reply With Quote
I haven't read up yet, but your not cheering me up you know
ATB Dan.
omega0684
posted on 19/6/08 at 09:16 PM Reply With Quote
i dont believe it, i have been trying to get my megasquirt working for weeks and you do it in a day!
what is the big secret?
blakep82
posted on 19/6/08 at 09:21 PM Reply With Quote
oooh! hopefully that'll be me in not many weeks
mind you, i'm actually a lot further away from that than i keep thinking i am...
________________________
Cheffy
posted on 19/6/08 at 09:41 PM Reply With Quote
Way to go fella, congratulations!
Just mine (well Anita's) to sort out now.
Then there's a V8 waiting for you to play with.
Mart.
Farts are like Rock'n'Roll. You love your own but you hate everybody else's. Lemmy, Motorhead.
theconrodkid
posted on 20/6/08 at 06:05 AM Reply With Quote
i gave up on "easy" therm and got the right sensors,couple of quid from the USA
who cares who wins
pass the pork pies
scutter
posted on 20/6/08 at 05:32 PM Reply With Quote
Might be a good idea.
ATB Dan.
NS Dev
posted on 20/6/08 at 07:19 PM Reply With Quote
Originally posted by clairetoo
Well done !
This is what worries me about Megasquirt stuff!!!!
I have set up many fuel injection systems, and calibrate temperature controlled machinery at work.
There is NOTHING remotely technical about adding an offset factor to te output from a variable resistor, to calibrate it to a required reference point, and yet somehow megasquirt seems to make it tricky!!
Having met Claire she knows PLENTY enough about engineering in general and engines in particular to be able to do most things, so it is surely the software that makes it tricky.
its the first thing you do on any normal system on the pre startup checks, set zero point on coolant temp, just a case of telling the ECU what the actual coolant temp. is with it switched on and reading the temp sensor.
paulf
posted on 20/6/08 at 08:08 PM Reply With Quote
I never even tried to use easytherm, I used a sensor from a vauxhall for the water temp and adjusted the bias resistor in the ECU to suit and managed to find a thermistor in the RS catalog that matched the megasquirt spec for the air temp.
If you use ford sensors and change the bias resistors for 27k ones it also reads correctly apparently.
Easy therm is supposed to be a quick easy way, but is not a 100 percent correct over the span and seems to cause plenty of firmware corruption problems.
Paul.
