cliftyhanger
| posted on 22/6/08 at 10:02 PM |
zetec silvertop to blacktop-Easy?
have a silvertop 1800 zetec at the moment, considering a brand new engine. So is it hard to chnage from silver to black, and what about 1800 to
2litre
Are most of the bits on my current engine?
Clive
austin man
| posted on 22/6/08 at 10:26 PM |
why not step up to the 2liter silver top< straight swap all ancillaries will fit, keeps the cost down. I think new engine mounts are required for
the blacktop. If you do go down the 2 litre silvertop use the 1.8 flywheel Its a lot lighter. you could even consider as I am of just changing the
cams to those from a 2 litre for a power hike, and stiching throttlebodies on if your running injection. is the 1.8 firked
Dusty
| posted on 23/6/08 at 01:23 AM |
I used the same engine mounts but needed to change the alternator mount and add an idler pulley for the alternator/water pump belt. Apart from those I
can't think of anything else. Sump may be a problem but my aftermarket one and manifolds were a direct swap. Blacktop ECU map totally different
to the silvertop one although it will run on both.
r1_pete
| posted on 23/6/08 at 07:49 AM |
Sumps are interchangable, but the windage tray is built in to the cast intermediate sump on the blacktop, and the tin windage from the silvertop
isn't a direct fit because the main caps are deeper on the silvertop. On mine I used the longer silvertop main bearing bolts with spacers
machined, see my photo archive for pics.
austin man
| posted on 23/6/08 at 09:27 PM |
have you considered the duratec option this has greater power and tuning potential especially if your after BHP for your bucks
