Steve Lovelock
| posted on 23/6/08 at 05:31 AM |
XE - low oil pressure when hot - causes?
Hi, I ran my car for the first time this weekend driving from London to Newark and back. On the way there (in rain) the oil pressure dropped to
40-50lbs but on the way back it fell to 30-40. The engine temp was cool at about 80 degrees. The only other thing is that I could have the timing
and the fueling wrong as I haven't really sorted my MSnSE ECU. Also, the oil is new but not exactly top quality. No oil is being burnt and I
have an oil cooler.
Any ideas on what this is about?
carlknight1982
| posted on 23/6/08 at 06:33 AM |
change your engine oil and put a good spec oil in, its not uncommon to see this in engines that have been stood or havent had a good oil change in a
while as oil is hygroscopic like brake fulid, it absorbs water from the air.
AndyGT
| posted on 23/6/08 at 08:17 AM |
wouldn't the water come back out of the as steam in the breather?
carlknight1982
| posted on 23/6/08 at 11:32 AM |
yes it would but that was more of a secondary explenation, i see oil pressure problems on a daily basis at work where the oil is either too old of too
worn out to do the job, remember a good oil has a life span be it in KM or Hours running. and the harder an engine is working the harder the oil is
working
mad4x4
| posted on 23/6/08 at 11:45 AM |
Could also be the grade of Oil . It could be getting to thin when hot and therefore pump cannot maintain pressure. Check the oil spec is correct for
the engine type.
Scot's do it better in Kilts.
| posted on 23/6/08 at 05:26 PM |
Change it for a decent spec oil of the correct grade . Vauxhall oil seems to be OK .Not sure what the correct pressure should be but it may be worth
checking.
