Author: Subject: exhaust bobbin vertical or horizontal?
Bluemoon
posted on 4/7/08 at 06:15 PM Reply With Quote
Should I mount my mini bobbin vertically or horizontal? It's a 907 can..
Also should the bobbin/mount be at the rear end of the can, middle or front?
Dan
indykid
posted on 4/7/08 at 06:19 PM Reply With Quote
rear of the can and with the studs vertically unless you want to change it every 1000miles. it's about all mine have lasted.
tom
posted on 4/7/08 at 06:24 PM Reply With Quote
I've done 5000 miles with the bobbin horizontal - but it's a light silencer that's held up quite well by the exhaust pipe.
Logic says that vertical should last longer...
907
posted on 4/7/08 at 06:35 PM Reply With Quote
If you want a larger bobbin the one off a Renault Espace can be used.
Search for Rubber mounts by 907 for a pic
HTH
Paul G
Edit to add...
Bloody hell!!!! I posted that can on 11/7/05
You do realise that the warranty has run out.
[Edited on 4/7/08 by 907]
Bluemoon
posted on 4/7/08 at 06:51 PM Reply With Quote
Taking my time...
Dan
:{THC}:YosamiteSam
posted on 5/7/08 at 02:10 PM Reply With Quote
when i was talking to dax - they told me to mount the bobbin 45 degrees to the engine side due to engine movement when revving - due to the exhaust only being attached at the manifold and the rear of the can it allows the exhast can to move better reducing stresses in the collector area - apparently..
bimbleuk
posted on 6/7/08 at 07:08 AM Reply With Quote
They work best when compressed as other stresses won't break the rubber but might separate the rubber from the metal plates. Depends on how big they are really as I'm using two small engine mounts either end of my heavy 6" can.
paulf
posted on 6/7/08 at 09:04 PM Reply With Quote
RS components do some nice rubber bobbin type mounts that have a 10mm tapped hole in each end and are about 50mm long and 30mm dia .I used one mounted vertically and have had no problems since fitting it, I found mini type exhaust mounts and a few others i tried only lasted a few miles.
Paul
