Author: Subject: if it's not one thing it's another :(
ditchlewis
posted on 5/7/08 at 09:35 PM Reply With Quote
well the old girl has been off the road for a month now
i fixed the cam followers and fired her up and all was fine ran like a dream. then the fuel pump fell apart
replaced that with a electric pump, but as i was removing the trans tunnel cover to wire it in i noticed that the paint on the drivers floor was blistering.
discovered the brake master cylinder has dumped all the fluid into the foot well.
this was a new cylinder and has only done 800 miles. the cylinder was fitted as it came out the box. should it have had a rubber boot over the push rod to keep the fluid in, of have the seals just packed up?
will this car ever run this summer? i'm getting very down about this
i get no time to fix it during the nice months as the family want to go out and hence no money to spare for parts
ditch
omega0684
posted on 5/7/08 at 09:49 PM Reply With Quote
just be a meany and say no going out this week and spend it all on the car!
chris_smith
posted on 5/7/08 at 09:53 PM Reply With Quote
chin up pal, im in sort of the same boat kids want to play out with dad in the sun, holidays are here soon and they need entertaining etc so i know how you feel but everything will sort itself out
im sure, i just keep plugging away with what i can when i can, at least yours is road legal, mine isnt blooming finished yet
remember it aint all that bad in the clear light of day, and worse things have happened at sea
posted on 5/7/08 at 10:14 PM Reply With Quote
Bad news, the boot only keeps dirt out and the seal's gone if it leaks
ditchlewis
posted on 6/7/08 at 06:30 AM Reply With Quote
that's what i thought
as it happens i do have a spare in the garage the one form the donor. i replaced it because i could not bleed the brakes ( the calipers were on upside down)
can you get repair kits for the seals?
ditch
ps off to legoland today only a 2 hour drive each way
i've also got an eye infection that i need to see the doc about tommorrow i think the earliest he will be able to see me is mid day so not worth going into work i think
[Edited on 6/7/08 by ditchlewis]
posted on 6/7/08 at 06:55 AM Reply With Quote
You may be able to get a repair kit from your local motor factors , I think Bennetts have a branch in Ipswich ? If no joy there then Past Parts in Bury St Edmunds may be able to help. Do you still have the invoice for the faulty cylinder? it may be worth having a word with the supplier?
NeilP
posted on 6/7/08 at 08:17 AM Reply With Quote
Ditch,
We haven't had a summer anyway so you've not really missed anything. Having the car available when you know what it can do and you can't is IMHO worse than not having it available...
You'll sort it and then the sun will come out for three months!
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
posted on 6/7/08 at 10:54 AM Reply With Quote
If you've got an eye infection it might be worth trying to get some chloramphenicol over the counter. You don't need a prescription for the drops anymore....
Was the old MC old? Maybe the seals perished in storage if they were dry?
ditchlewis
posted on 6/7/08 at 05:42 PM Reply With Quote
i've used bennets before so i'll give them a try.
the old master cylinder was ok when i took it off but that was a couple of years ago, and as for a receipt for the new one i've moved twice since that was installed..
i know it will be worth all the agro, the first year or two were always for Snagging and tweeking, it's just i'm addicted to the thing and i will even take it out in the pouring rain i just miss the old girl
i'll spend the afternoon tommorrow tarting around with it, i may even get the master cylinder replaced, i'll give the old one a go as i've nothing to loose, and if it works i'll fix the other one for next time.
ditch
Schrodinger
posted on 7/7/08 at 08:52 AM Reply With Quote
You could try LSUK in ipswich
http://www.lsuk.co.uk/branch_locator/ipswich.html
Keith
Aviemore
