matt_claydon
| posted on 13/7/08 at 09:53 AM |
Anyone got a Volvo with a 5-cylinder engine?
My dipstick is missing the plastic top so I need to know the length from the MAX line to the bit of plastic that makes contact with the top of the
tube.
Matt.
[Edited on 13/7/08 by matt_claydon]
Volvorsport
| posted on 13/7/08 at 10:17 AM |
erm , not sure if i have a dipstick .
did you resolve the clutch issues ?
i did measure me shaft length , they worked out at 5mm inside teh bellhousing .
www.dbsmotorsport.co.uk
getting dirty under a bus
Mr Whippy
| posted on 13/7/08 at 11:05 AM |
it's 46.8cm going by my engine, which is the 2.5 20v straight 5 one, P reg.
matt_claydon
| posted on 13/7/08 at 04:29 PM |
Thanks Whippy. Mine's the 2.3T but I expect they're pretty much the same.
I ended up using the super-heavy dual-mass flywheel and a modified release lever and now have a working set-up. Unfortunately it's somewhat
non-revvy so I'll be looking to get a custom solid flywheel made up at some point.
It's a bit smokey and there's oil in the inlet, so I'm guessing the turbo bearings are shot. Goes like absolute stink though
Barry Ashcroft
| posted on 18/7/08 at 08:24 PM |
Mate of mine is building one of these N/A to go in a westfield should sound lovely
