Author: Subject: fuel problem ?
Valtra
posted on 17/7/08 at 07:40 AM Reply With Quote
fuel problem ?
Hi my car is now registered but it broke down a couple of times on it's first journeys last night , spluttering to a halt with what seemed like fuel starvation , but after a couple of mins rest it started again quite hapily , there doesn't seem to be any vacuum build up in the fuel tank ( has a one way breather valve) and no apparent leaks . the fuel system is a mixxed bag of second hand and refurbished parts . Facet pump -filterking-twin forties. I've turned up the fuel on the carbs since SVA but it flufs a bit at low revs before clearing it's throat and going , could it be pressure , if the filter king is too restricted? any thoughts greatly apreciated
Ian
posted on 17/7/08 at 08:04 AM Reply With Quote
Hmm, i had similar problems on my Fiat TC with 40's in my Striker... it used to stop then I would flatten the battery trying to start it. After recharging the battery it started no problem.
I put it down to the 40's overfuelling in some areas of the rev range and under fuelling in others. This all resulted in the engine flooding with petrol and the time to recharge the battery allowed it to dry up. All this happened even though I'd spent some time on the RR.
So, your looking for a fix? Sorry all I did was take it out and put a Montego turbo engine in.
Have you considered a bike carb conversion?
mr henderson
posted on 17/7/08 at 09:51 AM Reply With Quote
Could be a blockage in the fuel supply that is floating away from the blocking point when the car rests (happened to me with a pre-crossflow Ford I was convinced the problem was electrical but it turned out there was some rubbish in the float chamber)
Or it could be electrical, sometimes components such as capacitors get hot, fail, when they cool they start working again (happened to me with an old A series)
Sounds like some forensic investigation is called for while the engine is still in failure mode. Try whiping a spark plug out next time it happens. Is it wet (with petrol) does it spark when the engine is cranked and the plug is earther against the block?
John
[Edited on 17/7/08 by mr henderson]
Davey D
posted on 17/7/08 at 10:08 AM Reply With Quote
On my old fiat Uno it started playing up when on a drive.. it reacted like i was running out of fuel... the car would lose all power and start slowing down to a crawl... if you let the car cool down then it would be fine to start, and run again.
In the end it was the electronics in the distributor that was breaking down when the engine warmed up. It is a common problem aparently, and once i fitted a new one then the problem went away :-)
graememk
posted on 17/7/08 at 11:11 AM Reply With Quote
i had a prob like that with the indy and again it was the coil
Dusty
posted on 17/7/08 at 12:22 PM Reply With Quote
If your Facet pump is the solid state one with the facet prefilter. Ditch the prefilter and use a cheapo plastic cartridge one. The facet ones block very easily.
Valtra
posted on 17/7/08 at 04:47 PM Reply With Quote
Thanks everyone . bit more info , the ignition is Lumenition competition spec with matched high power Lumenition coil bought second hand and fitted with fingers crossed but the car starts and runs so must be working , I had the wrong radiator cap fitted without a rubber seal which caused it to overflow onto the ignition system a few times but that was cured before the current round of problems , I still suspect fuel, the facet is the larger barrel type (red top if I remember right) which also has a cartridge pre filter between it and the tank . The Filterking has a bit of adjustment is that a possibility?
mr henderson
posted on 17/7/08 at 04:59 PM Reply With Quote
Not really, not unless your problem only occurs during periods of heavy fuel use
John
Valtra
posted on 17/7/08 at 07:20 PM Reply With Quote
Thanks fellas. Touch wood it never hapens again ....Mmmmm
Valtra
posted on 12/8/08 at 07:50 PM Reply With Quote
200 miles under my belt now . still having a few breakdowns it seems to be worse during low speed running once fully warmed up . miss-fires and poping and banging if you catch it quick enough and rev it . the car splutters then revs cleanly and accelerates then when you back off again back comes the poping and jumping. The car is still running un-known jets and roughly set up timing .
Thinking out loud , is it worth turning down the fuel a tad so that it runs rougher at first then once warm it's not choking on perhaps too much fuel ?
as usual all your contributions greatly apreciated.
Ian
flak monkey
posted on 12/8/08 at 07:54 PM Reply With Quote
Take the jet covers off and pull the jets out, post up what they are and I'll tell you if they are roughly right. Your idle jets could be miles out, but would usually play up all the time.
Defo sounds like fuel starvation. If its too rich you will get black/grey smoke from the exhaust when the throttle is blipped. Too lean and the carbs will spit back (not backfire!).
Check the timing with a strobe would expect a good starting point to be around 10deg BTDC.
Sera
http://www.motosera.com
flak monkey
posted on 12/8/08 at 07:56 PM Reply With Quote
Where in the world are you, someone might be able to pop over and give you a second opinion.
Sera
Valtra
posted on 12/8/08 at 08:05 PM Reply With Quote
Thanks for that info I'm on the Lincs/ Cambs border nr Crowland
omega 24 v6
posted on 12/8/08 at 08:29 PM Reply With Quote
Not usually a problem at this time of year but I have seen the carbs icing up. Or fuel vaporisation due to heat. Or try running with the filler cap off altogether (just in case there is a vacuum )
Valtra
posted on 12/8/08 at 08:35 PM Reply With Quote
Thanks , but hard acceleration seems fine so surely tank vacuum would nobble that, I have a (motorbike) one way valve tank breether also
"If it looks like it works and it feels like it works, then it works"
flak monkey
posted on 12/8/08 at 08:50 PM Reply With Quote
Hard acceleration with fuel starvation usually temporariliy overcomes it with 40's due to the pump jets.
Found this out myself after my breather pipe got kinked the other week
Its worth going for a run with the fuel cap off or loose to see. Either that or drive till you get a problem then pullover and remove the cap, if it sucks air in then you have a problem.
If I get a free evening I could pop over and have a look, given some decent weather, you arent far from me anyway. Friday would be a good day, U2U me and we can arrange something if you want?
[Edited on 12/8/08 by flak monkey]
Sera
Valtra
posted on 12/8/08 at 09:01 PM Reply With Quote
Cheers David
I'm harvesting (weather permitting) at the moment so can't make arrangements very far in advance, unfortunately for this situation good driving weather is usualy good combining weather also, but it's very good of you to offer . will u2u my postcode anyway cheers
DarrenW
posted on 13/8/08 at 08:09 AM Reply With Quote
Ive hd similar problems before in the early days.
1. Car would run fine, then start to splutter, then die. Would start up but gradually got worse and worse. This turned out to be the ignition amplifier. Changed for 2nd hand Motorcraft (OE) one and it was fine again (2.0 Pinto on early type electronic ignition).
2. While using 38DGAS carb, on heavy acceleration under load car would miss. Turned out to be blocked fuel filter. Crap from drilling the tank to fit sender unit (even though i was careful) had found its way into fuel filter. Changed it and all was well.
Only other problem i had with DGAS carb during car build was when using facet red top pump - way too powerful and regulator couldnt cope with the pulsing of the pump even though turned right down. This caused engine to flood, plugs to soot up etc. Changed to mechanical pump and all was well.
posted on 13/8/08 at 01:09 PM Reply With Quote
check also you don't have an air leak on the inlet side - you are using thackery washers and have done them up correctly? and if using the rubber 0-ring spacer, are the o-rings in place?
Valtra
posted on 13/8/08 at 07:08 PM Reply With Quote
up date ....
the jets are
long ones .f49
short ones 50 f26
not using thakeray washers, using the rubber jobbies may need tighteneing a tad they all have a 2-3mm gap between the plates . do get the occasional pop and spit back through the carbs, but I put it down to old school tech.
cheers
Valtra
posted on 14/8/08 at 12:51 PM Reply With Quote
just pushing up the page
flak monkey
posted on 14/8/08 at 02:38 PM Reply With Quote
Sorry for not getting back to you last night.
Ok the short ones are the idle jets and holders. These control the mixture upto about 2,500rpm or so. 50F9 are the best starting point, and yours arent far off that.
The long ones are the main jets and emulsion tubes. From your numbers it sounds like you have webers and not dellortos. The long ones should be in 4 parts. The screw in holder (the top bit), the main jet (the bottom bit), the emulsion tube (the middle bit) and the air corrector (fitted to the top of the emulsion tube, under the holder). Expect the main jets to be around 140's and emulsion tubes to be F16/F9 or F2.
Spit back is leaness on that choke, timing miles out or valve clearances wrong.
Sera
flak monkey
posted on 14/8/08 at 03:12 PM Reply With Quote
PS Valtra, you have U2U
Sera
Valtra
posted on 14/8/08 at 05:55 PM Reply With Quote
Cheers David
So do you , I'll whip out the mains again and have a look if I can strip them down to find some more numbers ...or even better .... a few earwigs and hedgehogs blocking them .
cheers
Ian
Valtra
posted on 14/8/08 at 08:42 PM Reply With Quote
Main tube f49
top hole (under holder) 135,
hex end 115
no hedgehogs.
cheers
Ian
