Author: Subject: Type 5 and Type 9 Gearboxes
Alfa145
posted on 18/7/08 at 10:24 AM Reply With Quote
Does anyone know if the type 5 box I have has the same bolt pattern as a V6 type 9 so I can just swap my bellhouse from one to the other giving my Essex 5 gears instead of 4?
[Edited on 18/7/08 by Alfa145]
Mr Whippy
posted on 18/7/08 at 10:38 AM Reply With Quote
well the v6 bolt pattern is the same as all the other type 9's BUT the input shaft length is different (v6 being longer)
Mr G
posted on 18/7/08 at 10:46 AM Reply With Quote
Bellhousing recess for the selector rail out the front will be different as the type 5 is 3 rail. Also 6 bolt instead of 4 for the type9.
Consul/Granada Bellhousing required
[Edited on 18/7/08 by Mr G]
mcerd1
posted on 18/7/08 at 11:06 AM Reply With Quote
I guess your best bet would be a type 9 from a 2.8 (long input shaft and V6 bellhousing)
but I'm not sure if this will fit or not
I think the questions should be:
Does the Essex 3.0 V6 have the same bolt pattern as the Taunus/Cologne 2.8/2.9 V6 ?
and how do the input shaft lenghts compair? (relative to the bellhousing length)
Alfa145
posted on 18/7/08 at 11:31 AM Reply With Quote
Thanks for the info. Seems to rule out Using existing bellhousing/clutch/etc with just a change of box.
So as the previous poster says my next question is.....
Does the Cologne have the same bolt pattern as the essex?
If so would I need to change flywheel/clutch/starter etc?
Mr G
posted on 18/7/08 at 11:38 AM Reply With Quote
Essex bellhousing>engine bolt pattern is different to a cologne if that's what you mean.
V6 Cologne bellhousing>gearbox bolt patterns are the same as normal type 9's (2.0l etc)
As mentioned in my other post you need a consul/granada bellhousing
Have a look at the 5 speed conversion info page HERE
