Author: Subject: Turning engine
speedyxjs
posted on 19/7/08 at 05:27 PM Reply With Quote
Turning engine
Spent this afternoon trying to adjust the valve's on my midget (1500) but cant turn the engine.
We've tried removing the plugs to release pressure and moving the fan but the fan just moves under the belt. We have also tried putting the car in gear and rolling it forward but the car wouldnt budget (and yes the handbrake was off ) i can just about reach the crankshaft from underneath but havnt got a socket big enought to fit on it.
Does anyone have any other idea's how to turn the engine?
redscamp
posted on 19/7/08 at 05:30 PM Reply With Quote
jack up one wheel ,put it in 4rth gear and
turn the wheel by hand
robertst
cant you turn it with the starter engine? from what you said it sounds like the engine might be seized?
Tom
speedyxjs
posted on 19/7/08 at 05:33 PM Reply With Quote
No she runs fine. just a tapping noise. From what we saw when we took the rocker cover off, they are quite far out and need adjusting
mr henderson
posted on 19/7/08 at 05:43 PM Reply With Quote
Have another go at pushing the car. I haven't come across an old car that I couldn't turn the engine over by doing that (in top gear with the plugs out). Otherwise there has got to be something else wrong.
John
posted on 19/7/08 at 06:17 PM Reply With Quote
Tapping noise on a Triumph 1500 engine is usually a big end bearing -- they are notorious for it.
[Edited on 19/7/08 by britishtrident]
clairetoo
posted on 19/7/08 at 09:10 PM Reply With Quote
I'd start with gas-flowing the head , maybe bigger valves and a hot cam , a bit more compression , a full balance and lighter flywheel , twin 40's or maybe throttle bodies ................ oh hang on , turning the engine............ I thought you said tuning
Its cuz I is blond , innit
Claire xx
Will weld for food......
austin man
posted on 19/7/08 at 10:13 PM Reply With Quote
Id be a little worried if it ran fine then wont turn over after adjusting the tappets may want to relook at the tappet setting first
D Beddows
posted on 20/7/08 at 12:46 AM Reply With Quote
Suggestion? Buy a big enough socket to fit on the end of the crankshaft you tight a*se! - adjusting the tappets is a job you'll be doing again tbh so a couple of quid on a socket (and I'm not even going to ask how you think you've been able to adjust the tappets without being able to rotate the engine btw !?......) would be money well spent
[Edited on 20/7/08 by D Beddows]
speedyxjs
posted on 20/7/08 at 08:16 AM Reply With Quote
I havnt adjusted them jet because we couldnt turn it.
Before you call me a tight a*se, just remember we are on locostbuilders
speedyxjs
posted on 20/7/08 at 08:17 AM Reply With Quote
That will all come after
mr henderson
posted on 20/7/08 at 08:44 AM Reply With Quote
So, did you have another go at pushing it yet? If it won't turn over like that, with the plugs out, then there is something else wrong.
Maybe you are just not pushing hard enough?
John
posted on 20/7/08 at 08:55 AM Reply With Quote
Totally agree, without the spark plugs fitted the engine should be quite easy to turn. I can remember doing the valve clearances on my dads 1500 Midget by gently pushing it in 4th with the plugs in.
It's a horrible engine though, makes a dumper truck look refined. Fortunately he sold it and now has a RWA 1275 which is far nicer car all round.
speedyxjs
posted on 20/7/08 at 05:37 PM Reply With Quote
I like it. Makes a great noise.
I wont try it till the weekend now but will post progress
posted on 21/7/08 at 08:38 PM Reply With Quote
Dads old 1500 was a bit rough admittedly, but the best noise I ever heard from the engine was when it wasn't running
