Adam
| posted on 21/7/08 at 05:18 PM |
R1 Engine SVA
Hi all,
Got my SVA on friday an i have a 2000 carb R1 engine. I have fitted a cat.. just wondering how i get the emissions down for the SVA... i also have a
pipercross sausage style filter. Any advice would be much appreciated.... It's like being back at school and getting all nervouse about exams
Adam
omega0684
| posted on 21/7/08 at 05:44 PM |
I had r1 carbs on my pinto at sva, and when he tested the car it was well over, then we just turned the little tuning screw thingies down and it
passed!
richardh
| posted on 21/7/08 at 06:10 PM |
mine passed without a cat no problem
smart51
| posted on 21/7/08 at 07:10 PM |
My 98 R1 passed with a cat. I took it to an MOT centre before the test and adjusted the idle mixture screw until the lambda reading was in the range
then tweaked them so that the HC were low enough. It failed SVA the first time because the cat was either dead or too weak. HC was too high but CO
and lambda were OK. A new cat fixed it.
the 2000 R1 needs to have the air thing removed and blocked up.
Adam
| posted on 21/7/08 at 07:58 PM |
"the 2000 R1 needs to have the air thing removed and blocked up." any ideas what these are, Thought i'd done everything to the
engine that needed doing just thought/hoped i could just adjust the mixture on the carbs.
Adam
