paul the 6th
| posted on 22/7/08 at 01:26 PM |
Haynes manual "Rebuilding and Tuning Ford's CVH engine" quick question
Just stumbled across
this
book on the haynes website whilst lurking for sierras on ebay and literature on amazon.
Description from the website:
"The Ford CVH engine has been used in many well-known Ford models including Fiestas (1.4, 1.6, XR2i and RS Turbo), Escorts
(1.4, 1.6, RS1600i, XR3, XR3i and RS Turbo) and Orions (1.3, 1.6 and 1600i). This detailed book gives a brief history of the unit followed by
advice on rebuilding and tuning an engine in the home garage, describing what can be undertaken by the enthusiast and what should be put out to
specialists. It includes chapters on carburettors, the exhaust and ignition systems, and illustrates all stages of engine stripdown and
rebuild."
It doesn't say anything about sierra's in there? Just fiestas, escorts and orions... Would this still be of much use to those using a cvh
from a sierra? or did ford make some significant changes to the cvh after the sierra? Just wondering since this could be an ideal accompanyment to the
sierra haynes manual
[Edited on 22/7/08 by paul the 6th]
GoDesign.me.uk - Self Adhesive Vinyl Artwork, Wide Format Printed Artwork and Customised Heat
Pressed Clothing...
http://picasaweb.google.com/haynesroadster - Roadster Photo Build Log
whitestu
| posted on 22/7/08 at 01:30 PM |
It won't be relevant for the 1.8 CVH, just the smaller ones.
Stu
Paul TigerB6
| posted on 22/7/08 at 01:31 PM |
I personally wouldnt bother fitting a CVH engine myself - you'd be better with dare i say it a Pinto or Zetec (but what you really want is a
bike engine!!  ). The CVH isnt the most tuneable and you will not find it so easy to buy off the shelf parts like manifolds etc
stevebubs
| posted on 22/7/08 at 01:45 PM |
2 words (sort of)
RS Turbo
paul the 6th
thanks for the replies guys
if you have a quick look at this thread you'll see my rationale behind going
for the 1.8 cvh. I'm not too bothered about mental power/tuneability and since it's my first ever attempt at anything like this (not from
an engineering background & I don't have any friends who know about this stuff) so I wanted to stick closely to what the book says. There
seems to be plenty of sapphires with the cvh & type 9 'box floating around.
If I can find a decent serra with a pinto engine I'll be tempted to maybe reconsider.
Also, once I get my head around my first project, I'm going to go mental and fit a turbo busa engine to a single seater (or something along
those lines)
Pressed Clothing...
whitestu
| posted on 22/7/08 at 01:56 PM |
Depends what you want.
I fitted a 1.8 CVH for SVA purposes with the plan to change to a Zetec later. It made the build dead easy as all the ignition and induction bits were
already working on the donor.
You can also pick up second hand Westfield tubular manifolds for reasonable money [the 1.6 ones fit].
As you say the 1.8 isn't great for tuning, but my Indy with one in wasn't exactly slow. It probably had around 100BHP with the Westfield
exhaust and K&N filter.
They are very tough, quite light, compact and sound nice as well.
Depends what you're after really. I've had a few issues with the Zetec in mine and have to admit wishing I hadn't bothered to swap
over on a couple of occasions.
I don't think you'll be disappointed with a good 1.8CVH.
Here's one I made earlier CVH Vid
Stu
[Edited on 22/7/08 by whitestu]
paul the 6th
| posted on 22/7/08 at 02:43 PM |
nice one stu
thats the ethos behind my build. I'm seriously not bothered about big power (as I've got 2005 suzuki sv650 sport which'll hit 60 in
around 3.5 seconds and is good for 145 mph).
a 1.6 or 1.8 engine in a car which weighs 700kg's shouldn't exactly be slow and it will handle better than most standard audi tt's
(at a guess?). It's more about the building/learning experience. Once i've finished my first one, I'll happily go for bigger power
and more complex designs.
It's just a case of trying to find a decent cvh. At first glance there appeared to be loads of them on ebay but most of the serra's are
dohc's or automatic chv's
Pressed Clothing...
Jenko
| posted on 22/7/08 at 03:03 PM |
Don't agree :-) - The CVH is very tuneable, the heads actually flow very well as standard, but with a bit more work, can flow much better - the
main reason being the very large valves.......
They are light (alloy head), and very simple to work on, and the bottom end is effectively a zetec......
The main issue here is the difference between the 1.8 and 1.6, and they are quit different - Not saying there is anything wrong with the 1.8,
it's just as they were not fitted to too many cars, and not much tuning was done on them......
Now then, although I said I disgree with Paul Tiger B6 - He does have a valid point (although not the pinto bit) - A zetec would really be a better
choice due to cost, and power as standard.....
I run a 2ltr CVH with head work / solid lifters, double springs on Motorbike throttle bodies - it's very quick , and would beat a standard 2ltr
zetec (i.e. more bhp / torque)....That said, it cost quite a bit of money, and a Standard Zetec can of course be tuned to produce more power.......
I know you have reasons, but honestly, If I was building another car, I would stuff a 2ltr Zetec in as they really are so cheap to buy now....
The type 9's mate up as do the Mt75's, but you need to be careful with diff ratios
paul the 6th
| posted on 22/7/08 at 03:17 PM |
it's my first build and I am scared! lol
top information from everyone though thank you very much
Pressed Clothing...
Surrey Dave
| posted on 22/7/08 at 03:35 PM |
Poppy cock and balderdash!!
I was one of the first to build with a 1.8 cvh , they always draw negative comments because tuning parts aren't generally available as this
engine was derived from an american 1.9 version I believe.
But in standard form is much better than a standard crossflow or pinto, and if you sort an exhaust ,ditch the ridiculous small pierburg carb , and fit
either a uk cvh distributor or megajolt ignition they are surprisingly acceptable , smooth , torquey ,simple to work on.
I also skimmed the head on mine 1mm and spent some time cleaning up the port shapes.
Been to one Lotus track day with mainly elises ,and those vx sport things, I can honestly say that I was not at all embarrassed by the performance and
some on here may confirm that.
So all in all a cheap simple effective engine for 1st build.
And to concur with 'Whitestu' I have had a Zetec waiting for fitment for 2 years , but everytime I go out I think this ole 1.8CVH ain't
too bad at all.
[Edited on 22/7/08 by Surrey Dave]
paul the 6th
| posted on 22/7/08 at 04:07 PM |
that was the impression i got with the cvh...
"tuning parts aren't that readily available" does not = Crap engine
there always seems to be someone somwhere, who has a nice bit of advice like the above. Or there's usually a company who can supply a couple of
bits even if they're a bit more expensive than the equivalent for another engine.
I'm happy enough with the cvh as it seems to be simple enough but will offer a great learning experience
Pressed Clothing...
James
| posted on 22/7/08 at 04:28 PM |
Some interesting CVH comments here:
http://www.pumaracing.co.uk/index.htm
fancy 400+bhp?
James
- Muhammad Ali
Jenko
| posted on 22/7/08 at 05:07 PM |
ain't too bad at all.
Couldn't agree more - Again, I think the 1.8 gets a bad time, but it really seems to be only because there is a lack of tuning parts available
for them - And by that I'm really talking about cams, and lifter upgrades...I know changing to an agressive cam profile on the 1600 cvh engines
and moving to solid lifters makes a massive difference..I also know the standard CVH does not run the nice roller lifters seen on the 1800, so the
dreaded cam wear issue should not be so bad......
paul the 6th
| posted on 22/7/08 at 05:17 PM |
ah now it's becoming clear....
so when "there's a distinct lack of tuning parts", there are bits and pieces out there but the pinto has much more available for
it?
I think I'll be happy sticking a k&n and an exhaust (plus any other neccessary mods to the carbs/sparks) and that'll do me until I get
tired of being left behind on rides out
Pressed Clothing...
| posted on 22/7/08 at 07:58 PM |
Sadly in this case it does. The 1.6 isn't a bad engine, cam wear issues aside, but the 1.8 has numerous differences which were made to improve
emissions. One of those is a particularly poorly flowing cylinder head design.
It's possible to make a hybrid using the 1.6 head and 1.8 bottom end, but it's not a straightforward or cheap job as there were so many
changes.
If you are happy with the standard power output then it's fine. If you want more power afterwards then put a Zetec or something else in the
car, don't try tuning the 1.8.
Surrey Dave
| posted on 22/7/08 at 08:03 PM |
Ferriday Eng.
This who you need if you want to put 1.6 head on 1.8 motor:
http://www.ferriday.co.uk/
Gaskets .adapter plates , pistons.
But it is much cheaper to fit a Zetec.
Jenko
| posted on 23/7/08 at 09:14 AM |
Yep - Mike (from Ferriday), was the one who built my 2ltr bottom end - It's a very nice piece of kit...but it ain't cheap!.
paul the 6th
| posted on 23/7/08 at 09:40 AM |
think I'll hang fire on the tuning for a little while lol.
Thanks for all the info/advice/opinons from everyone
Pressed Clothing...
