bob
| posted on 22/7/08 at 02:30 PM |
Inlet manifold nuts
I had to remove my inlet manifold last week (fireblade carbs) and i'm wondering when refitting wether to change the nut type.
I used nylocs last time but did read that the heat from the head can reduce the lock from the nylon on the nut, i was wondering what others have used
or since i didnt seem to have any issues with the nylocs should i just stick with them ?
bob
| posted on 22/7/08 at 03:00 PM |
Rob
I was thinking on the same line, since i have a load of M8 SS cap heads
whitestu
| posted on 22/7/08 at 03:13 PM |
I used the same.
Stu
austin man
| posted on 22/7/08 at 11:09 PM |
if your concerned any nut with threadlock/ nutlock should do or a spring washer
paulf
| posted on 23/7/08 at 09:49 PM |
Nylocs will be fine on the inlet manifold, they shouldnt get any hotter than the max water temperature.I have fitted my inlet manifold with short set
screws and spring washers and had no problems .
Paul.
