LBMEFM
posted on 28/7/08 at 08:02 PM |
Fireblade speedo
I have read previous past threads and are still confused. I have got a 95' Fireblade engine in my MK Indy using the original Fireblade clocks.
What do I have to do to get the speedo to work.
Thank you
Barry
posted on 28/7/08 at 08:20 PM |
If you have the original speedo pick-up which locates to the bolt on the sprocket, you can modify it to run on your diff output.
Something like this;
Phil
posted on 28/7/08 at 08:32 PM |
Alternatively, you can use a speedo sensor from a 98 onwards Fireblade and mount it externally to pick up signals from magnets attached to the diff
output.
Phil
LBMEFM
posted on 28/7/08 at 08:37 PM |
Thanks Phil
mark chandler
posted on 28/7/08 at 09:41 PM |
Nine magnets on the prop adapator saves you needing a speedo healer.
I did not have the correct sensor so used an old ABS sensor, works just fine and was free!
mike smith1
posted on 29/7/08 at 09:40 AM |
I would recommend the post 98 sensor, as for magnets i would advise that you drilled and tapped small bolts into the prop adaptor as in my experience
the magnets tend to let go after a short while!
I will post a pic of how we have done it if required.
The main reason i chose to use the post 98 sensor was that i could then use the post 98 clocks which i think look better than the pre 98 clocks.
Mike
[Edited on 29/7/08 by mike smith1]
LBMEFM
posted on 29/7/08 at 07:31 PM |
Hi Mike, pics please if poss, will the 98 sensor be OK for my 95 clocks.
Barry
