markyb
| posted on 2/8/08 at 10:34 PM |
fuel pump problem
I tried to start my 03 R1 today but there is no fuel making it to the engine from the fuel pump
when I turn the key the pump starts ok but constantly runs with no fuel making it to the engine
The fuel filter is just before the pump (bosch) and there is plenty of fuel in it so I know there is fuel going in but there does not seem to be any
coming out the other end
has anyone come across this problem ?
MkIndy7
| posted on 2/8/08 at 11:54 PM |
Is the pump directional..?
Is it definately in the right way and the electrics connected with the correct polarity?
It could be trying to pump backwards maybe
| posted on 3/8/08 at 09:25 AM |
Then you tend to get a bubbling noise from the fuel tank... apparantly..... accourding to someone I know......
If it constantly runs it means it's not building up pressure. Normally it'll run until the floats are full then stop (assuming a 03 R1 has
carbs??). Sounds like the fuel isn't getting to the pump!!!
markyb
| posted on 3/8/08 at 11:11 AM |
thanks everyone - as predicted I had got the polarity wrong so pump is now working !!!
next step is to get her started (hopefully)
