Author: Subject: Filter King servicing
greggors84
posted on 3/8/08 at 05:22 PM Reply With Quote
Im having what seems like a fuel starvation problem and working my way from the tank to the carbs making sure everything is clear.
How do you get the filter out of a Filter King fuel regulator?
Does the bowl simply unscrew? Does the adjusting screw need winding out first?
Chris
The Magnificent 7!
posted on 3/8/08 at 05:26 PM Reply With Quote
If it's one of these bunnies:-
Image deleted by owner
Then all you have to do is unscrew the big thumb-wheel at the base, then pull the wire retainer to the side. The cup can then be removed, giving access to the filter.
One warning: the cup will contain a fair amount of petrol!
posted on 3/8/08 at 06:14 PM Reply With Quote
yes - undo the nut below the bowl (can be glass), then the u-shaped wire can be moved out of the way to releasethe bowl.
spares can be obtained from FSE (fuel system enterprises)
