Author: Subject: 83 BHP :(
caber
posted on 3/8/08 at 09:17 PM Reply With Quote
83 BHP :(
I had the car on a rolling road yesterday and got a dead regular peak of 83BHP crank at around 4800 RPM on my Pinto 1600 with twin webber 40s. This was a first run and the carbs are probably not jetted right. What do you think I should be able to get when this is set up properly?
Caber
Pdlewis
posted on 3/8/08 at 09:25 PM Reply With Quote
I cant say what you should get on twin 40s but mine on 30/34 (I think it was ) setup proply made a whole 78bhp when it was done
Build Photo Album
Updated 05/02/2009
NS Dev
posted on 3/8/08 at 09:26 PM Reply With Quote
put an XE in it??
StevieB
posted on 3/8/08 at 09:30 PM Reply With Quote
Time to see the light and go BEC
johnston
posted on 3/8/08 at 09:40 PM Reply With Quote
Is the 40's the only mod???
If so i reckon thats not bad seen worse out of "preped " 2.0l
[Edited on 3/8/08 by johnston]
blakep82
posted on 3/8/08 at 09:45 PM Reply With Quote
wot NS Dev and stevieB said...
________________________
CaptainJosh
posted on 3/8/08 at 09:47 PM Reply With Quote
Get it jetted properly then also, think about getting the ignition setup properly, i think you should easily be able to see 100bhp with that engine.
Easier then doing an engine swap, full stop.
[Edited on 3/8/08 by CaptainJosh]
zilspeed
posted on 3/8/08 at 10:11 PM Reply With Quote
Bog stock 1.6 Pinto makes 75bhp. Non injected 2.0 makes 101bhp. All as bolted into the Cortina / Sierra.
To be fair, maybe 90 horses, tops with the webers ?
Stick a zetec in there. It's the easiest solution.
NigeEss
posted on 3/8/08 at 11:40 PM Reply With Quote
83 ponies in a car that weighs little more than a crisp packet will still wee off most
of the Corsa boys
nitram38
posted on 4/8/08 at 02:53 AM Reply With Quote
I don't feel so bad about my F1-2 now!
Only a 1.4 K-series inj and getting 105 bhp at the crank.
Also only £120 road tax!
speedyxjs
posted on 4/8/08 at 07:07 AM Reply With Quote
You've all got it wrong
PUT A JAG ENGINE IN IT
swanny
posted on 4/8/08 at 07:50 AM Reply With Quote
Go V8. Buy medallion, and chest wig.
Mans engine.
i had a two litre pinto and that did 100 at the flywheel and 75 at the rubber bits.
loggyboy
posted on 4/8/08 at 08:41 AM Reply With Quote
Originally posted by NS Dev
put an XE in it??
Or if you wanna keep it on the cheap, just a 1.6 8v GM lump would see 120+bhp on 40s
I guess thats the problem with a engine thats design is so dated, most bog standard 1.4s will give 80 brake nowadays.
[Edited on 4/8/08 by loggyboy]
posted on 4/8/08 at 09:28 AM Reply With Quote
As said, 83bhp sounds about right. My stock rebuilt 2.0 with DGV weber, K&N filter and tubular manifold etc made 107bhp on the rollers by comparison.
Marcus
posted on 4/8/08 at 11:24 AM Reply With Quote
Was that 83 bhp at the wheels or crank?
If at the wheels, that's a good result for a small Pinto. If at the crank, I'd suggest getting the jetting sorted or even stick a 2.0 injection head on it with the 40s. Should get you closer to 90 / 95.
Marcus
Because kits are for girls!!
posted on 4/8/08 at 12:11 PM Reply With Quote
83bhp isn't bad at the crank for an otherwise stock 1.6 engine with sidedraught carbs. It's not a performance engine by any standards.
Fitting the injection head without modifying it is only going to lose power; the combustion chamber volumes are significantly larger on the 2.0L heads, so the CR on a 1.6 engine would be too low.
The simplest mod would be to fit a 2.0 boat anch...er..Pinto. It will bolt straight in using existing mounts, exhaust manifold etc. and will give a good power and torque improvement over the 1.6. For significantly more power a more modern engine would be a better starting point.
iank
posted on 4/8/08 at 01:00 PM Reply With Quote
The number you get also depends on the rolling road you take it to so absolute figures can be rather misleading.
There are lots around that give wildly over optimistic readings because that's what customers want to tell people at the pub, and the rather less impressive 'real' numbers from a properly calibrated road will just lose them customers. Conversely some will give you a real number in the hope of getting some work tuning it up.
So long as this is understood and the operator doesn't 'cheat' between runs it's fine for testing incremental improvements. But I wouldn't get too hung up on the number you're given so long as the engine is pulling strongly and you are happy with the actual road performance.
Anonymous
caber
posted on 4/8/08 at 08:01 PM Reply With Quote
Well that sounds not too bad. Right now I am running F16 correctors with 120 jets , 40F9 Idles and 30mm Chokes. Looking at Dave Andrews article he reckons 135 main jets and 34 chokes. Any one got any other suggestions or places to look? Also anyone have any 33 or 34 chokes for 40s they want to sell and a set of medium slot in trumpets for 40s? My bolt ons were judged unsuitable as they flare too slowly.
TIA
Caber
tcr
posted on 6/8/08 at 05:48 PM Reply With Quote
ditch the 40's and fit some bike carb's the price is about the same after messin about with jets and belive me the differance in cold starting and running in general is unbelivable
MK MIDI ZX10R
http://www.facebook.com/media/set/?set=a.4393256076054.2182513.1427988207&type=1&l=64c91c3c17
why isnt anything simple!!!
torquetune.co.uk
nrpexhausts.co.uk
