Eggy
posted on 10/8/08 at 07:59 PM |
Fuel tank breather?
I've knocked this off..........
[img]
Fuel breather 2
[/img]
Any idea where I can get another from?
bob
posted on 10/8/08 at 08:26 PM |
I got my one way breather valve from thinkautomotive in Isleworth middlesex.
http://www.thinkauto.com
RichieW
posted on 10/8/08 at 08:40 PM |
Theres some cheap ones going on ebay.
item number 380048788403
scoop
posted on 10/8/08 at 08:45 PM |
Do you always need one of these?
RichieW
posted on 10/8/08 at 09:09 PM |
I think so. As the engine sucks the fuel out of the tank you have to replace the missing volume with something otherwise you get a bit of a vacuum
created. Thats the theory anyway. Dunno if it's any different in practice mind. Depends if your fuel cap is 100% air tight or not I suppose.
The one way valve stops the fuel escaping in case you flip the car over but I expect leaking fuel would be the least of your worries then.....
nitram38
posted on 10/8/08 at 10:49 PM |
Some advice:
Get a two way valve. It will still shut off the fuel if inverted.
Tanks need to breathe both ways.
Your tank will pressurize in the summer and if you have a return pipe it could explode. I kid you not.
When you use only a one way valve, air is drawn in to replace the fuel that is drawn out, but when some of that fuel is returned to the tank, it is
not able to push the air back out.
I destroyed a bosch inj pump that way too..................
[Edited on 10/8/2008 by nitram38]
mark chandler
posted on 10/8/08 at 11:01 PM |
I cut an old inner tube up, this gave me a schreider valve and brass insert that it screws into. This is a good fit for some 8mm fuel pipe as its a
self contained unit.
So I could vent out as above I nipped the spring out the valve so it would not be held closed.
dr-fastlane
posted on 11/8/08 at 06:24 AM |
One my car I used one from a Audi 80. It's cheap and reliable. On the audi it's on the rearbulkhead in the trunk, atached with some
rivets. Up to the scrappy
I have not failed once. I have successfully found ways that will not work!
https://www.motor-forum.nl/threads/hardtail-dragstyle-project.343482/
dr-fastlane
posted on 11/8/08 at 06:29 AM |
pictureImage deleted by owner
posted on 11/8/08 at 09:05 AM |
old car tyre!!
pah!!
I'll raise you one ballbearing, biro spring and some brass tube!
