| posted on 12/8/08 at 11:18 AM |
Starter Motor Position
Does the FWD IB gearbox put the starter in the same position as a type 9 RWD bellhousing??
I want use one of the Ford FWD boxes as an adapter for my Toyota Supra box. The newer IB5 which has a nice hydralic release bearing might be better
but the starter is opposite the original position. Were these used in zetec engine Escorts and Mondeos??
I will just be using the front half of the casing with an adapter plate behind to mount the Toyota box. Its getting to be quite a common approach now
with other members on here doing the same. Any advise chaps??
flak monkey
| posted on 12/8/08 at 11:50 AM |
Your top pic the starter is on the same side as a std T9 bell housing.
Sera
http://www.motosera.com
stevebubs
| posted on 12/8/08 at 11:52 AM |
Factory starter position for a FWD zetec car is the top left when looking from the timing belt....
To get it to fit in the bottom right on a blacktop, you have to grind away parts of the sump....
will121
| posted on 12/8/08 at 04:19 PM |
think the first gearbox you show is the same as the one fitted to the FWD in the CVH engine, as the CVH engine bolts straight up to the type 9 gearbox
and the starter is in exactly the same position so should be ok.
