Author: Subject: Ignition Map
posted on 14/8/08 at 09:43 PM Reply With Quote
Ignition Map
Anyone got an ignition map suitable for a ST170 engine. Standard Ford values will do as a starting point.
I thank you
posted on 15/8/08 at 08:05 AM Reply With Quote
You really need someone with a timing wheel, a timing strobe and a ST170 engine in a car.... Then it's quite easy to whip the map.... That's what I'm doing when replacing the Honda 2D ECU with an Emerald EFi 3d ECU.
