mat.price
| posted on 17/8/08 at 02:43 PM |
pinto dipstick leak
Has anyone had the some trouble?
The dipstick on my pinto leaks all the time where it meets the engine
i’ve use liquid metal to try to stop it and at the moment i’ve been using ptfe tape but know the oil starting to leak again!!
What have other people done to stop it??
Thanks for any help
Matt
mookaloid
| posted on 17/8/08 at 02:51 PM |
mmmm they are a bit tricky.
It's important to make sure there's no crankcase pressure building up to force oil out by having a good breather system as well as using a
sealing compound of some sort.
Also consider bracing the tube near the top with a bracket so that it doesn't move around and break a good seal.
Mark
stevec
| posted on 17/8/08 at 03:26 PM |
Perhaps take the tube out, get a pair of pointed pliers and carefully flair the end the tube slightly. This will make it a tighter fit. Then degrease
the tube and the hole and loctite it back in.
Steve.
mat.price
| posted on 17/8/08 at 05:37 PM |
im looking into crankcase pressure build up but i have not seen anyone using anything different then the standard pvc vaule?
as for the breather system i have the some setup as most people?
bob
| posted on 17/8/08 at 06:17 PM |
When i had my pinto i had the same problem, i found a good clean and degrease of the dipstick tube and plenty of araldite cured the problem.
Liquid metal should have worked, i'm thinking its all in the degreasing 1st so the chemicals can cure.
iscmatt
| posted on 17/8/08 at 09:23 PM |
AH! i have this problem too, how do i take the dipstick out without breaking it??
DarrenW
| posted on 18/8/08 at 08:22 AM |
It is tricky.
Firstly - make sure dipstick tube is a neat fit and the top bracket is firm so movement is minimised.
Secondly - Crankcase pressure. I had big problems with too much oil. A search for about 14 months ago will reveal the investigation and solution.
Assuming dipstick is correct and oil level is good next look at the valve. If using std carbs, std PCV should work as inlet vacuum opens it to relieve
the pressure. However with mult carbs you cant do this. Again loads of posts in searches. Some people replace the PCV with Burton unit. Others modify
ford unit (take out ball, plunger and spring so its straight through. Others fit the cortina style oil trap breather (my solution). Ive then fed the
outlet to a bottle with biggest bore pipe you can get away with (1/2" for me). Also fed oil cap outlet to same bottle.
For bottle - some people use fancy oil catch tank, others a drinks bottle or various other locost solutions. All seem to work well.
The biggest improvement i got in stopping dipstick leak was improving crankcase breathing. If pressure builds up the engine will force out vapours
(and oil) whereever it possibly can - path of least resistance etc.
DarrenW
| posted on 18/8/08 at 08:23 AM |
If dipstick is tight in hole then leave it. Dont remove unless absolutely necessary. Look at other potential issues first.
mat.price
| posted on 18/8/08 at 05:15 PM |
ok people thanks for the info
ill have a look into it and see if that sorts it out
:{THC}:YosamiteSam
| posted on 20/8/08 at 07:55 AM |
you could remove it altogether - tap a thread in the hole bung a bolt in.. manufacture a dipstick of the same dimensions so you can check it when
needed.. an old stock car trick
