Author: Subject: Propshaft
triumphdave
posted on 19/8/08 at 12:04 PM Reply With Quote
Propshaft
Should there be locking nuts,locking washers or tabs or something on the propshaft flange bolts?Mine were loose
tegwin
posted on 19/8/08 at 12:06 PM Reply With Quote
If your bolts go straight into the flange then use locktight and a split washer...
If your bolt goes through the flange use locktight and a nylock on the other side....With some washers of course!
www.verticalhorizonsmedia.tv
posted on 19/8/08 at 12:08 PM Reply With Quote
Originally mine had bolts with a special coating (from Ford). Looks like blue paint when you undo them.
I used a Loctite locking compound when I replaced the bolts (the sort of compound that can be undone with a bit of effort).
Dingz
posted on 19/8/08 at 12:57 PM Reply With Quote
Ford still sell the proper bolts for the sierra, they are about £1.30 each I could look fot the pt. no. if you need it.
[Edited on 19/8/08 by Dingz]
RickRick
posted on 19/8/08 at 02:28 PM Reply With Quote
hmm loctite damages most plastics, i think that applies to nylon used in nlyloc nuts too, so using both together might be counter productive
triumphdave
posted on 19/8/08 at 03:52 PM Reply With Quote
Thanks but mines a cortina based.
I will try loctite stud lock.
Cheers guys
NS Dev
posted on 19/8/08 at 06:08 PM Reply With Quote
yea just use loctite
posted on 19/8/08 at 06:11 PM Reply With Quote
And tighten them properly - they're usually at a fairly high torque setting, which can be hard to achieve on something that's designed to rotate!
hellier0437
posted on 20/8/08 at 09:20 PM Reply With Quote
does anyone know what the thread is for the bolts that go into the flange?
thanks
