black.viper
| posted on 31/8/08 at 12:14 AM |
Type 9 Gearbox filling/lever hole location
Please, can anybody mark to the photo location of gearbox filling/lever hole plug? I little bit confused but on Haynes manual is very bad photo and I
cannot find it!
Thx very much!!!!
Petr
Im building Tiger Cat E1 Duratec engine
Paul TigerB6
| posted on 31/8/08 at 12:17 AM |
You have got it in your first pic mate!!! With the car on a level you need to fill the box so that the oil is just about to overflow the filler plug.
| posted on 31/8/08 at 08:13 AM |
The plug you have pointed out is the level plug. Probably going to be very tight so use a decent allen key and if needed a piece of pipe as an
extension. Make sure you use the correct oil
The Baron
| posted on 31/8/08 at 08:14 AM |
This method has never worked for me because, when i fit my engine & gearbox I drop all of the oil because of the angle it has to go in at (mine
wont fit from below) so I have modified my top cover to have a fill hole, nice & easy
B
Paul TigerB6
| posted on 31/8/08 at 08:41 AM |
B
How do you check you have the correct oil level then?? I always filled mine in the car through the filler plug shown. Access is pretty tight in the
transmission tunnel but not so hard as to make the job impossible
The Baron
| posted on 31/8/08 at 11:00 AM |
Because the box is empty, its done on the quantity i put in.
B
| posted on 31/8/08 at 02:26 PM |
Thats alright until it leaks.
The Baron
| posted on 31/8/08 at 03:40 PM |
I got bigger problems if it leaks on SHMBO new block paved drive
black.viper
| posted on 1/9/08 at 08:22 PM |
Thank you very much for everybody... engine have to go out... hmmm ...
becouse I absolutly dont have space there for anything.
Cheers, Petr
