se7ensport
| posted on 31/8/08 at 10:56 AM |
how stretchy is silicone hose?
Simple question: will a 57mm silicone hose fit over a 60mm O/D pipe?
| posted on 31/8/08 at 11:12 AM |
Silicon hose doesn't stretch much compared to rubber hose. Rubber hoses you can heat up and it becomes more pliable. I think you'll
struggle with a 3mm difference and silicon hose...
martyn_16v
| posted on 31/8/08 at 11:55 AM |
32mm silicone hose fits onto 34mm outlets on my engine, so I reckon you should be OK. Don't blame me if it's not though
Stott
| posted on 31/8/08 at 01:36 PM |
In my experience, yes with a bit of a push, the last bit I did to the tintop boost hoses was fitting a 51mm ID elbow over a 53mm OD pipe I turned up,
but I also put a 2mm lip on the edge to stop it blowing off and managed to get the pipe over that too
(It was samco 4 ply, others can be even more stretchy)
HTH
RK
| posted on 31/8/08 at 01:45 PM |
Yes but you have to work it. I have found rubber ones harder to stretch over pipes, but maybe the size difference was just too big.
Werner Van Loock
| posted on 31/8/08 at 02:40 PM |
Think good rubber hoses get stuck to the surface faster then silicone, silicone tends to slide easier
http://www.clubstylus.be
se7ensport
| posted on 31/8/08 at 02:56 PM |
Thanks for the info guys, looks like its a go then
I'm putting four of these in my airbox to connect to my throttle bodies:
